I’ve got some very light scratches on my bonnet due to it being washed with a scrubber which was a little too ruff. They are probably only 1/10 of a mm deep, & can only been seen in the right direction of light which causes them to reflect.
I tried wax, “wax on, wax hoff”, but did not work well enough. Is there a product which can remove these light scratches?
Thanks :P
A cut and polish should do the job. It should take about a 10th of a mm off your clear coat, which would even it down to the depth of the scratch. (and is also why you shouldn't cut and polish more than once a year apparently)
just be carefull when you do it...
1.minimal elbow grease - small amount of cut and light pressure - you would be amazed how quickly you can f*k your paint
2.do the entire panel in an even manner - other wise you will end out with a visible faded area.
luckily your car is white! white hides all :glare:
Jolinator PM's Sez:
please dont use cut an polish on your car, that shis is for commodores not proper cars, if you want to remove the scratchs properly without doing more damage to the paint, get yourself a bottle of meguairs scratch x, is has special particles in it that will smooth the scratchs over, without ripping off clearcoat etc,
i am a detailer for a living so if you have any questions let me no.
Good one :ermm:
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
