ill be posting pics on friday of my new car. i got the call today and apparently it will be ready for thursday pickup :miner:
:P Congats.
Can't wait to see pics.
Totally different league to the S14....
Here she is.
5ZIGEN exhaust fitted
Dolphin bodykit fitted
ISC suspension fitted and dialed in
Feels and drives awesome ... like a new car :miner:
Picture001.jpg:P
Hear are a few pics on my 2003 NM35 Stagea ARX.
Still pretty stock except for suspension and swaybars.
Cheers
Andy
It looks much tougher now with the new stance, Andy!
Hey all,
I gotta say a big mention to terminal, leetom and XMetal for their cars.
These stageas truly inspired me to buy mine.
Tough looking, and not too overstated.
I'll post up some updated pics of mine when i get my new parts on.
Cheers!
Edited by dirtyrs4
Cheers
Andy
*continues stuffing money into his mattress and whispering "next year, next year"*
ohh nice!!! love the rims!!!!
PS mine still isnt ready :P apparently its ready today but later today. fooken dealers!!
Oh the waiting game pain!!!!!.....how I remember that!!!!
LOL.....also the comment "all you will want is an exhaust... then suspension... then rims... then....." only the turbo, ECU, Geabox and swaybars to go for me...just got to find about 5K.
On the rims part.....thoughts people....I'm lost.....the rim in the pic on the black ARX? Yes or No?
Edited by Jetwreck
I think they would look great!
A quick visual aid...
your the shit....could I ask one more small favour as I am stuck between that and the one attached.....please buddy pal mate!!!!!
Black & white for sure - nice contrast... but you gotta colour code the grey ARX "beard".
Done the turbo, exhaust & rims, got the ECU (Emanage Ultimate), dreaming of the CV8 with paddle shift, swaybars will be by the end of the year, can't do suspension until I move into a house without a rediculously steep driveway.... *Is that my bank account I hear screaming?*
btw. Did you get the wiring diagram you needed for your Haltech?
(in the workshop manual thread if you haven't)
Edited by iamhe77
Haha! Use your imagination! I think the contrast of the silver edge would work better too. The red highlight will be much more subtle and blend with the wheel/tyre blackness. Really depends on what appeals to you in the end.
I am out of play time for today sorry...
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
