hey chuckie, i like the newer rims, but why did you change the grille ? i reckon the mesh style grille is much nicer, :domokun::):) well N/A grill much better to clean then RS4 ,+ i didn`t like RS4 grill so iam happy ,yes now looking to find another set of 350z rim`s so i have at least a SPARE & set for track work when i can do it ,
cool mate, i mean i am not bagging you, just wanted to know why !
you love your yellow wagons :D
PS: couldn't that commodore grille make some nice chips out of big potatoes :D:D:D
YES & BLOODY HARD WORK TO KEEP CLEAN , :domokun::):)
  • 1 month later...
post-20831-1237622877_thumb.jpgpost-20831-1237622923_thumb.jpgpost-20831-1237623101_thumb.jpgpost-20831-1237623149_thumb.jpgafter a little indiscretion and a bit of cosmetic damage to the front and rear of my dayz kit i thought this is a bit of a chance to go from stealth to show, while the dayz is getting repaired i opted for the nismo kit available locally, still trying to come to grips with the transformation, so i'll just stick up a few before and after pics to give you a bit of a peak.
Thats exactly what I thought......
is that 502 at all 4?
List of engine mods please.
engine bay photos please this things wagon PORN.
At all 4, yes:
An older engine photo. I'll take new ones and post soon
Engine:
RB26DETT
Each engine component balanced to 1 / 1,000g, then as a complete system to 1 / 1,000g
N1 Block
Tomei Forged Pistons
Tomei Forged Conrods
Tomei Forged Crank
ARP Conrod Bolts
Custom Ported and Polished Head
Custom Valve and Valve Seat Design
Tomei Cam Shafts
Tomei Slide Cam Pulleys
Tomei Valve Springs
Tomei Valve Spring Retainers
Tomei Valve Buckets
Tomei Valve Guides
Nismo Plenum
N1 Oil Pump
N1 Water Pump
Nismo Oil Baffles
HKS T04Z Turbo
HKS Extractor Manifold
HKS Front Pipe
HKS Drag 60mm External Wastegate
HKS 100mm Dump Pipe
A’PEXi 100mm Exhaust
HKS Air Filter
HKS Map Sensor
HKS Intake Piping Kit
HKS Compressor Outlet Piping
GReddy Induction Hard Piping Kit
Twin ARC Blow Off Valves
Nismo Engine Mounts
Nismo Gearbox Mount
Nismo Metal Head Gasket
Tomei Metal Throttle Gaskets
Tomei Metal Intake Gaskets
Tomei Oil Restriction
Nismo Main Bearings
Nismo Big End Bearings
Nismo Centre Bearings
Complete Nismo Seal Set
Gates Racing Belts
Blitz 10 Series Racing Platinum Plugs
HKS Metal Exhaust Gaskets
Procoated Piston Crowns
Procoated Piston Walls (Teflon)
Procoated Manifolds
Procoated Dump Pipe
Custom Blow Off Valve Control System
Custom Oil Catch Can
Custom Air Separator
Custom Overflow
Custom Water Spray Tank
Splitfire Coils
Fuel System:
Nismo Fuel Pumps [Lift] (x2)
11 litre surge tank
Bosch 044 fuel pumps (x2)
Sard 800cc Injectors
Sard Fuel Pressure Regulator
Tomei Fuel Rail
Custom Dual Fuel Cooler System
Cooling:
GReddy 600mm x 300mm x 115mm Core FMIC
GReddy Hard Piping Kit
GReddy Oil Cooler
GReddy Oil Filter Relocation Kit
GReddy Radiator Piping
Tabata Twin Core Alloy Racing Radiator
Custom Water Sprayer System
Custom Power Steering Cooling System
Suspension:
BC Suspension
Kazama Adjustable Rear Castor Arms
Kazama Adjustable Rear Toe Arms
Ikeya Formula Adjustable Rear Camber Arms
Kazama Adjustable Pillow Mount Rods
Nismo Sway Bars
R33 GTR Strut Bar
Drivetrain:
R33 GTR Gearbox
Nismo Super Coppermix Twin Plate Clutch
Nismo Chromium Molybdium Fly Wheel
Nismo Pressure Plate
Nismo Release Bearing
Nismo Slave Cylinder
Tomei LSD
Brakes:
Brembo Calipers
Brembo Rotors
Endless Pads
Electronics:
HKS F-Con V Pro ECU
HKS EVC V Boost Controller
GRID TS Dancer
HKS Turbo Timer
Defi BF Boost Gauge
Defi BF Fuel Pressure Gauge
Defi BF Oil Pressure Gauge
Defi BF Exhaust Temp Gauge
Defi BF Oil Temp Gauge
Defi BF Water Temp Gauge
RevLite Sequential Shift Light
Exterior:
Custom Front Bumper with additional air rams for oil cooling, air intake etc
260RS Side Skirts
260RS Rear Bumper
Ganador mirrors
Nismo Smoke Indicator Lenses
Dolphin Spec 2 Grille
Interior:
Dolphin 300km/h Speedo
Dolphin triple meter hood
Series 3 R33 GTR Seats
Nismo Gear Knob
Momo Wheel
Nismo Floor Mats
Rolling:
Rays / Volk GTC 18” x 10” 2 piece forged +17 Wheels
275 x 35 R18 Toyo Trampio all round
Nismo Valve Caps
ICE:
Pioneer AVH-P7950DVD Touch Screen DVD
Pioneer DEX-P01ii Head Unit
Pioneer DEQ-P01ii Equaliser
Pioneer CD-IB100
Pioneer CD-RB20
iPod Nano
Kicker K\ZX850.4 Amp
Kicker ZX1000.1 Amp (x2)
Kicker ZX200.2 Amp
Kicker Remote Bass Control
Kicker Hyper Flex Power Wire
Kicker S8L7 Subs (x4)
Hybrid Audio Legatia 6.5” (x4)
Hybrid Audio Legatia 3” (x4)
Hybrid Audio Legatia 1” (x2)
Custom A Pillars
Custom Door Pods
Custom Door Panels
Custom Sub Enclosures in Boot
Extra Batteries
Cooling Fans
Additional:
Custom Radiator Breather Tank
Custom Overflow Tank
Custom PS Reservoir
Custom Stereo Battery Terminals
Custom Fuel Filter Brackets
Custom Fuel Rail Brackets
Custom Fuel Reg Brackets
All Oil Lines Braided
All Fuel Lines Braided
All Water Lines Braided
All Vacuum Lines Braided
All Manifold Lines Braided
All Wastegate Lines Braided
Performace:
502kW / 683HP @ wheels, 3,003Nm.
Pump Gas.
Daily Driven.
great to see this stagea complete? been following this build for a few years now on this site and on sdu, it has to be the BOSS, it needs it's own section with the build and vids(noise and smoke)....bow to the boss.
Cheers. I can post up a build post if ppl want. It will just be an f load of progression photo's.
i just fell off my chair ..... again ..
dude write that post up, and also E-mail HPI mag. would love to see a stagea in there ...
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
