pics taken at chinderah BP just south of the qld/nsw border, as for the controversy i'm not a 100% , i recall at the time a few people on here questioned it's authenticity.
It'd Be nice to know what they said, but it seems like there's an entire year missing from this thread, coz i have a couple of questions about its authenticity myself, eveything about it is an Autech, but then its things like it says its a 1996 on the compliance plate and is registered as a 96 car (was sold as a 99 but I didnt find that out till I'd received the car and the guy buggered off over seas)
what is the sure fire way of telling its real, coz for the bits that r in this thing it seems like a massive amount of time and money to make a fake, im sorry if this is off topic its just been something that been on my mind for a year now
cheers for any help
cheers for any help
Post up your VIN number and i'll check it on Fast for ya.
cheers for any help
I am not sure if you want to know the truth
Unfortunitly I have known the seller's doggy deals for over 12-14years.
Here is the original sales thread for your car back in 2003!!!
He want $128,000 for it. Notice he got banned
http://www.skylinesaustralia.com/forums/Au...l=autech+stagea
Pm me your phone number and I will fill you in. Do not really want to discuss over the forum
I have been burnt by this guy as well.
Sorry for off topic but just read that thread and laughed til I cried.Man that mr gtr was uptight! :D
I wonder if he knows or is the bloke that burnt me.
Autech's may be his favourite.
ahhhh, so you DID get the SSV one Tom.
Looks GREAT!
Where are you located?
yeah i definately did :) i'm pretty stoked so far!, once i drove it i just couldnt help myself and had to get it.
its abit of a change going from a 4cyl Daewoo Wagon to a Stagea :/
i'm getting my alpine headunit and my Mongoose m80g installed Saturday :D
located in Southbank!
yeah i definately did :D i'm pretty stoked so far!, once i drove it i just couldnt help myself and had to get it.
its abit of a change going from a 4cyl Daewoo Wagon to a Stagea :)
i'm getting my alpine headunit and my Mongoose m80g installed Saturday :)
Just a small change? :/
All we need is a Vic Stag cruise.... Now where is that Ryan1600 at??
i'd compare it to from riding a bike -> motorbike :)
i rarely see other Stags around. although i've seen a grey one three times driving on boundary road when i go to band practice. :D
(maybe i'm not looking in the right area!)
id def be in for a cruise though!
dont forget me ..... KEBABS FRIDAY NIGHT !!!!! check the VIC events sections ... STAGEAS ROCK UP!
im sick of being the only one there farking !
I checked the events section: Upcoming Victoria Events:
  • Anyone got anything to add?
I'd prolly turn up for something, if something was on.
Nice black ride dude. I love your bonnet - VERY nice.
  • Like 1
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
