OH! makes me think i should have taken pictures from when i moved house today! stag was CHOKERS!!!
Same, when i moved, managed a fridge(in box). also managed a 46" TV(in box) plus all the other crap.
Very Nice!! They look so nice in black.
Flip the little cover over the positive terminal or it wears thru the underbonnet heat padding stuff :)
Yeah I was charging up the battery and forgot to flip it back ....do you guy's know the color code of the dark blue for the 1998 stagea 260rs?
If you put the vin # into FAST it will give you the paint code.
If you dont have FAST PM me ya vin and i can do it for ya.
It should be on the factory ID plate below the model number(my guess is BT8) but put up your vin number otherwise for the definitive answer.
I sold my RS4 S on Friday, took one last pic before she got picked up. :D
what offsets are those? thats exactly how i want the wheels on my rs4s to sit, what did u use?
9.5 +15 all round with 235/40's
I have the wheels for sale, PM me if your keen.
i'm so poor its not funny, did u have any issues with clearance? did u have the guards rolled or anything?
Looks awesome. Pity the RS4V's don't have the same rear cradles to run rims with that sort of offset. I'm trying to squeeze 9.5 +25's under mine....
i'm running 9.5+15 on the rear of mine no problems at all.
on another note, just ordered my new wheels, so 4 months-ish (such a long wait :banana: ) and you'll see some more crazy wheel fitment :banana:
do tell mike...pm me if its a secret
Its all good! Only issue I had was the wheels would sometimes hit the coilovers but that was because I ran the car so low.
I would have prefered if the wheels had a +5 or even a 0 offset and ran the same camber all round (around 3 degrees)
on another note, just ordered my new wheels, so 4 months-ish (such a long wait :( ) and you'll see some more crazy wheel fitment :laugh:
What suspension are you running? I've got a set of Tein Style Master Super Low down Wagon Spec.... stupid funny names! My biggest issue is that I can't get the front end any lower. The rear I can drop another 2". Did you roll/pull/pump your guards to fit the +15's? Do you run camber arms?
    • Apexi SAFC - AFC 1st Generation Rare Old School JDM As you can see it all lights up in the photos and is in 100% working condition. Has been kept in storage and boxed for years there won’t be to many like this if any! Especially with all original packaging and manual. price:$650   APEXi SAFC 2  In Complete Working Condition Refer To Photos and view the video provided.  Price:$500   Located Melbourne - Australia Wide Postage Available At Buyers Expense  IMG_6981.mov
    • wow so i just logged back in after buying the 33 and joining SAU, And I've got all a whole bunch of you wanting to know more, well unfortunately it still doesn't run i was hoping it was seized from a snapped timing belt as i turned it over by hand and it was fine and then it did a few revolutions and jammed solid when i was running it with the key, so the timing belt is mint, I've also found a lot of the parts I'm removing have already got bolts undone or not quiet tight enough to be unsuspicious. so the plan is to find a running RB30 block and chuck my head on it.  I have a habit of buying stuff I don't need or require so for my none running engine i have a forward facing plenum , Apexi power fc, 40mm Turbosmart wastegate, And for the car its self coilovers ,low seat rails and BRZ seats (black seats with red stitching i already had these and they are ADR Approved and allow rear passengers access)
    • I took apart the dash and found this strange 2 pin connector. it dosen't seem like its factory or oem, any clue on why someone would add it and where it might have been connected too?
    • Not mention a SS2 especially with that rear oddly small rear housing. I feel the Facebook mechanics and experts has led OP in the wrong direction.
    • Won't get near 400kw, pump and injectors nowhere big enough. Bin the manifold and get off the shelf and a modern ECU.
