  • 2 months later...
hasn't been a meet for a while.. last one I missed anyhow! im sure the guys would be keen at some stage to organise one :P
p.s. mine needs a scrub too.. damn this spring rain!!! >.<
Edited by atomaly
hasn't been a meet for a while.. last one I missed anyhow! im sure the guys would be keen at some stage to organise one :ermm:
Mine is a dirty ho too. :P
I was trying to organise a Stagea Dyno day, dont want it too big but that would make a great Melbourne meet... Have to see if the owner is interested yet.
awesome, sounds good - maybe once the weather gets a bit fairer - although they have said it will be a wet spring, which is fvcked - so over winter.
and no fun at all for you with a black car!! i'm loving white already, so easy to keep clean, just pulled into the car wash this morning - $1 in the high pressure washer, sprayed off the dirt and its back to new!!
A couple of quick snaps I took a few months back.
looking good mate
whats the specs on the front mount? its pretty much exactly what i'm looking for
have to hack up the front bar/reo much?
looking good mate
Hey, thanks!
Cooler is abit of a custom item. If you look at the where the Inlet and Outlet is there's a weld separating them them. When I first purchased the cooler I got it home and had a closer look. it was more or less a Single tank. I figured Air will flow the route with the least amount of resistance, therefore rendering the core useless. So we removed the tank and cut it in half and welded in a plate that would divide the tank into 2x. Pressure tested and all.
Only down side to this design is when used on Big HP Applications there is almost guaranteed Boost Drop as the air would be cooled twice. No worries for a nimble Stagea :)
Reo copped the usual chop. As I mounted the cooler as low as possible to allow as much air exposure as possible. But I did a neat job with enough room to run a piece of Vac Hose along it to prevent any such rubbing. Also managed to retain all the Under Body plastics.
i would be up for a stagea meet sometime..dyno day you just want to show us how much power your car makes ..you win
But mine is only a little turbo, its only the fuel... I seem to remember you at one of the RE days talking about ecu's and turbo's. Arent you interested anymore?
Funny, as an M35 owner I used to look up to you c34 guys in awe at the power you could make with a quick chip and tune, after a lot of hard work I got there eventually. Now I want to help all the other guys...
Hey, thanks!
i might have to get you to help me out over summer, its one of the many things that is on the shopping list when i get back
yeh got the nistune done but nothing else atm lack of funds next fmic then look into high flow turbo its a slow process but will happen
  • 4 weeks later...
The family runner, finally got to take some pics.
not many mods, but have replaced the exhaust with a blitz system,
meisters, new ebc and some other stuff.
It took us to exmouth and back to perth nicely. [sans the ol manifold studs snapping]
has the RS steering wheel, and the whole family LOVES IT!
Currently on tein lowered springs, does need moar low tho. :(
give us a shout if you see it about! :blush:
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
