My M35. Pretty happy with how it looks. Perfect stance for me. Even at this height, I struggle with my low hanging Kakimoto exhaust. Next on the list - dump & front pipe.. deciding whether to go a mid muffler or hi-flow cat.. any suggestions..?
Very nice!:thumbsup: That is a really nice package with the 350Z rims; colour, ride height, all spot on.
The Aero looks so nice in Gold; almost as nice as Black...:whistling:
I'm still torn; not really sure about the Aero skirts on my Black; they look so good on the light colours, but on black they just look heavy.
Maybe I need to get hold of some PM skirts; more pumped than the stock ones, but less than the Aero.
Hmmm, might need to perve on Alex's at the Stag Anniversary...:ph34r:
I'm with Cam; a dump & mid pipe with a high flow cat will really wake it up. Exhaust volume won't really change; but you do get a nice burble once the restriction is gone.:whistling:
Edited by Daleo
I think the aero kit is just perfect for the M35.. i wasnt keen on the gold before the purchase, now i love it..
Not too sure about the PM skirts, but personally i wouldnt go any other kit besides the aero.
was for the exhaust, the reason i wanted to go a mid muffler was main for the flow, im not too concerned on the sounds side of things..
thanks for the input guys!
Mind you, when Jetwreck was under my car, all I heard was "mmmm, thats different, thats different , thats different"!!!
There seems to be more and more they changed S1 to S2.
Have to check it out Sunday. Hope we get some good weather.
Couple of photos of Longroof.
Fake RS260 bar on an RS4S
Giant sideskirts kinda dont suit the rear...
Failed rego inspection specifcation R32 skinny rim tuck for lols.
Was so embarassed to be sitting in my car in line behind a 996 GT3 and a newish Jag XKR at the inspectors with tiny R32 rims about a foot inside the guards.
The jag failed.
interstate cars may require a local inspection before rego is given.......
Yeah, I realise. I was just curious as to why the car might have failed the inspection.
Just picked up my Stagea from the autotrans depot this morning. Bought it in SA.
I'll have to take it to the pits to get a WA rego soon; not looking forward to that part.
Will post a pic when possible, maybe later today :D
not too sure,they are 18s but they are going cos they have bad gutter rash from the last owners.ill be getting 20s in the same style if i can find them,
Looks nice and clean. What wheels are they?
    • Ok cool, because I do have some OEM BMW options for light(er) wheels. 17x8.5 M Sport wheels are 11kg and I could put 255's on them. Maybe that's an initial test.
    • So, in the effort of pulling apart airboxes and testing enclosures to see if this aids in MAP loss at WOT I noticed: 1) The ducts up the OEM intercooler holes from the front bar help IAT drastically, whether the pod is shielded from the engine bay by an airbox missing a lid, or an airbox WITH a lid. Plus you get more induction sound without the lid. Having half the airbox (with no lid) acting as a barrier to the headers seems to help. 2) For shits and giggles I checked the TB. This was full pedal travel. This is actually full travel of the TB. Photos aren't perfect, but there was definitely an amount of play in it and it wasn't against the stop. After much swearing and adjusting the pedal, I realised that the cable is actually too long for the skyline pedal travel to fully articulate it. Having the pedal adjusted so WOT was actually hard open on WOT resulted in an idle of 3500rpm. As an aside, this was also the TPS registering at 3.1%. I removed the above to give the pedal enough travel to actually fully open the TB. I now get a satisfying 'thonk' on full open and full closed which you can hear pumping the pedal as it hits the TB stops (with the bonnet open and intake back on). Luckily for me, the screw screws into a raised metal boss under this plastic piece that is now acting as the new throttle stop. I've gained about 20mm (ish) of pedal travel and I can move it maybe a mm or two post open-thonk before it's hard against the stop. After all of this I did a bit of road tuning because a 102MM throttle is sensitive. The difference between holding an 950rpm idle and instantly stalling is about 0.4% of TPS movement. Will that help? I suppose it can't hurt. I set 'closed' point back to where it was, I can definitely feel the extra pedal travel that is needed to actually open the TB fully. But this morning I dropped the car off at Paint Jail again, so who knows when this will re-eventuate out to see if it helps with the top of the dyno hitting a ceiling.
    • Take heart that everyone else seems to have found a way. The OEM S1 indicators do slot in pretty firmly. It may simply be a case of having them sit slightly looser and nobody actually ever noticed this when attempting to remove a indicator from a JSAI bar :p
    • If the original NA ECU has a separate TCU then you are going to need to reroute wires that used to run between the trans and the TCU to the appropriate (1 to 1 equivalent) pins on the ECU. Other than that, it should work. Look up posts by @Kinkstaah on the subject.
    • So the stagea was a series 2 neo det with tiptronic auto. (I have the transmission aswell) and has integrated tcu in the ecu. I'm hoping to use the entire stagea ecu, engine and auto harness.
