this takeros stag is hawt
well done sweden
my RS4S takeros stagea resides in victoria w00t w00t fresh from japan.
and its genuine, including the CF bonnet, could use some of those eyelids though.
Edited by OMY31T
Koya Endless 19x8.5 235/35 tyres +12 offset all round, you can have rims made to order from koya. suspension is HKS Performer all round - if you havent seen these before, they were made inbetween the hypermax I and hypermax II, i had never seen them until i got them with the stag from japan, and i will say, they are pefrect for the street, i have hks hypermx in my r33, and the hard rock solid, these are nice for the street and still handle really well, i think the wagon handles even better than my r33.
  • 3 weeks later...
Yo!
Here's a few new pics now when the summer came to Sweden.
I also mapped the car with the new GT2530-turbos and the HKS 264/9.1 cams.
497whp at 1.4 bar, that's really impressing power at such a low pressure (still stock bottom).
Here's a movie, 50km/h to 220km/h: http://www.youtube.com/watch?v=OEAbxzyr8LQ
And here's a movie from the mapping (making ~400whp at 1.1 bar): http://www.youtube.com/watch?v=lVp8rNBlRgo
And here's the photos!
Yo!
Wow that looks freaking sweet...
Eyelids would match the grill... is that Dolphin?
Good to see it back on the road!
Yeah its Dolphin...I need to check our their eyelids as the only ones I can find on YAJ looks a bit ghey.
Yeah need skirts and rear but fark its expensive getting it from RHDJ....I haven't seen nismo bodykits on YAJ for a while...
I think I got lucky when I scored this bar landed for $400...
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
