It will have a watermark, just a quick low res pic the photographer sent through. There is a possibility it will end up in a mag...
Jun at work, this is my attempt at photography with my new Nikon V1. :)
Can't wait to see the whole shoot.
Below is my attempt with my Nikon D3100....low res shot linked for web ofcourse.
Welcome Daniel.
Full Giala kit? (the rear looks like it could be factory aero from that angle.
Ive got no idea what kits on it, either did the guy i got it from, I've never seen a kit like it and i thought it looked pretty cool... but from what your saying it does look like the gialla kit, unsure what the rear bar is ill post another pic this arvo :D
Welcome Josh! Where are you based in Adelaide? I think I've seen that around...
I'm from the Barossa.
Looks nice Josh!
What wheel size are you running?
Cheers dude, running 18x9.5 +12 Rota Grid R's all round.
Fellow Stagea owner from scotland :D
Welcome Dave. Nice example you have there. Enjoy your summer? Must have got up to a blistering 18 deg, lol. Good turbo driving weather tho :yes:
    • Maybe but doubt it, when I jacked it up it was creaking in the j arm again. The inners are all good, I inspected them. Remember that also it did fix the problem but temporarily.
    • Could be the other bushes. The inners.
    • Once you lose the adjustable bushes, you have almost no adjustment at the front for anything that matters. You can only wind so master caster at the front, and ~7° is fine. You won't have choice of front camber. If you only have rear camber arms (ie, do not also have adjustable upper tension arms), you shouldn't change their length very much, because you will introduce bump steer. And, you will struggle to find a workshop that will be capable of doing all the adjustment work necessary to simultaneously achieve a decent rear camber number, get the toe right, and minimise bump steer. I would guess there's probably 8 hours of work there. So, stockish rear camber is fine. Although, keep in mind, that stock camber, by number value, does not mean stock arm length when the car is lowered. You will need to lengthen the RUCA to get back to stockish values and that will require the tension arm to be lengthened a little also. Without any other guidance, any change made to the RUCA should have the 2/3 of the same change made on the tension arm. But that is only a rough rule of thumb and the relationship might not remain linear across a wide range of adjustments. And it might not also be as close to minimum bump steer as you could achieve if you did the bump steer measurement and adjustment properly.
