Post A Pic Of Your Stagea Thread
Good time Dale and great shot....
Is that a baby seat in the back???
Cheers Jase; pretty stoked to get the time too!
Why yes; yes it is, dad spec is the new sex spec. The after sex spec, if you will. ;)
And given half a chance; my young bloke would've been along for the ride...
Josh, the 18 x 9.5 +12 fit all good? any guard work needed?
I run 18x9.5 +12 on my s1, with 10mm slip ons on the front, ive rolled my guards all round, although have quite a lot of camber, if your're prepared to go quite low, they fit well.
  • 1 month later...
Took a photo up at Mum and Dads today inbetween working on the Xk120. This is pretty much my safest ride height and where it will stay. 335mm front eyelid, 330mm rear. It clears up over any driveways, gutters and gives good enough travel over the shitty roads (I do alot of onsite callout's Tweed/Goldcoast).
Even though my exhaust is tucked up pretty nicely, it's lowest point is 110mm off the deck.
Car drives so well still for what is now 335,000klms on stock turbo no rebuilds. Been running 12psi+ for the last 200,000 klms :D Roil Additive at the start and motul 8100 excess every 10k. Have to credit Nissan for building such an outstanding engine, driveline - everything.
Pennies are being saved now for a couple more suspension parts - front tension rods and swaybars. The clutch feels tired so probably needs doing soon and then I can get onto the better stuff in life - hypergear turbo, injectors, fuel pump, z32 afm, cams and nistune.
Jez
Jez
looks good always loved these yellow stageas
looking good Jez!
Makes me keen to get new wheels and coilovers for mine!
Also, blacked out grille and highbeams looks pretty good too
Thanks guys !! Appreciate it.
Because it makes it look less like a Series 2 and more like a series 1.... HA.
It does change it up a bit. Got a bit bored with the pig nostrils ( thats what i call the high beams )
Just a couple of pics of mine from the SAUQLD Charity cruise.
Thanks to Andrew and Chris for the pics.
Car looks great SABBAi, how the hell did I not know about this charity cruise. I am such a dope some times.
might as well post a pic of mine...
got a late model front end & some 20" VSKF's coming in a container..
here is a photoshop mockup of what it should hopefully look like in a couple months
Edited by loz-tuned
    • Noice one 👍 I've done a 1:16.300 at Watkins Glen, will keep at it. Still have to knock off half a second at Suzuka in the Roadster
    • Two golds! Struggled to get silver on Gran Valley.
    • Interesting that it has 2 to the USB stick. Are the ones to the USB stick different? Or labelled anything at all? Telstra 4G is Band 28 is the long range one you want, it's 700mHz. I'm trying to do some reading on the Cel-Fi stuff, but I can't find any decent info online that makes me feel comfortable being able to work out the sort of antennas we could get away to swapping it over to. The antennas I'm starting to do some stuff with at work, are a transparent antenna. They're designed to stick onto the window. Which means you wouldn't even have the antenna outside the car. Volkswagen have just started using the exact same types of antennas on some of their new cars (And from the same antenna manufacturer). But, RF stuff is a bit of a dark art some days, and getting it wrong in your car could make for a terrible waste of money trying to swap antennas :S
    • I'm not going to lie Duncan, Saturday and Sunday were pretty rough days. The sort of work I was doing would previously have ended up with me spending about an hour and a half chatting with Neil. Firstly about something I had a question about, and then both of us rambling off on tangents.  I think how Neil did things, and his attitude to getting it done is helping me in part to get this stuff done. Then I can actually do the things I enjoy more easily
    • Talked to another R34 GT-T owner, he said bonnet of his car once fell and slammed from full height because of strong wind at a car show and nothing was damaged or broken, so I guess I'm just overthinking some things but yeah, just making sure I'm not damaging the car anyhow cause wanna keep it for a long time.
