Post A Pic Of Your Stagea Thread
I told you they were coming! It's still a small % of us but they are coming!
I'm pretty sure they jumped in through the same window Aaron came through!
Edited by Jetwreck
Maybe you can rise up as their leader. They are all gunna want Epic wings like you and then you can change them for good,
Just like the soup nazi!
NO MORE CAR WORK FOR YOU!!!
Hey guys, new to skylines au, always had silvias so I converted to the dark side ?.
This is my new blank canvas, or the better halfs daily, you be the judge.
11/01 nm35 250 rs four v
cheers
Here's mine:
Owned since March 2010 - purchased from Japlink with 39K and now nearly 139K.
Mods include:
Hdi FMIC (installed by Dale), B+M transmission cooler sandwiched b/w FMIC and radiator (installed by Japlink), plenum spacer (installed by Dale), Selby sway bars front and rear (BG organised by Dale and installed by him), Dale's front chassis brace (also installed by him), Jetwreck's GB rear chassis brace (installed by Dale), BC BR coilovers (installed by Dale last Dec - with thanks), Brembo brake upgrade (installed by Japlink), transgo shift kit (installed by Jetwreck in the bro' garage), Scotty's 3" dump pipe and a custom 3" exhaust (installed by Japlink), air horns above the FMIC and pair of LED fog lights (both installed by Japlink), 19x9.5 +20 offset (bought from jasevr4) shod with Kumho KU31 245/40 (from Taleb Tyres Arncliffe),
Dude! That looks great, nice one.
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
