I told you they were coming! It's still a small % of us but they are coming!
I'm pretty sure they jumped in through the same window Aaron came through!
Edited by Jetwreck
Maybe you can rise up as their leader. They are all gunna want Epic wings like you and then you can change them for good,
Just like the soup nazi!
NO MORE CAR WORK FOR YOU!!!
Here's mine:
Owned since March 2010 - purchased from Japlink with 39K and now nearly 139K.
Mods include:
Hdi FMIC (installed by Dale), B+M transmission cooler sandwiched b/w FMIC and radiator (installed by Japlink), plenum spacer (installed by Dale), Selby sway bars front and rear (BG organised by Dale and installed by him), Dale's front chassis brace (also installed by him), Jetwreck's GB rear chassis brace (installed by Dale), BC BR coilovers (installed by Dale last Dec - with thanks), Brembo brake upgrade (installed by Japlink), transgo shift kit (installed by Jetwreck in the bro' garage), Scotty's 3" dump pipe and a custom 3" exhaust (installed by Japlink), air horns above the FMIC and pair of LED fog lights (both installed by Japlink), 19x9.5 +20 offset (bought from jasevr4) shod with Kumho KU31 245/40 (from Taleb Tyres Arncliffe),
Dude! That looks great, nice one.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
