awesome cheers dude - what tyres are you running to get that all under the arches - any modifications for them to fit or just slap them on? Lowered too?
tyres are silly at the moment. 235/35. Once these are catus, I'll be going for a 245/35. I could have just slapped them on and it would 'fit'. But I don't like rubbing the coilover body or chewing out tyres due to camber. So I have camber arms front and rear, Toe arms for the rear and lots of low. Make sure that if you want to run low, that you get toe arms, the standard arms don't cut it when you run them much lower than stock, you run out of adjustment.
My new toy. Fresh Stagea owner!
Keen to join the community!
Nice! I like it.
20131013_190847_RichtoneHDR_zps6964ae3f.
Went for a quick drive with a couple of mates, had to wait up a couple of times :-( dam slow Hondas
Got a quick snap in just before sunset
Edited by pipster11
cheers Nick. I'm considering going to Superlap, so if I do we'll have to catch up. Bring Liz.
Oh Scott, I spoke to Liz the other day, and she's probably not going to be able to make it to WTAC due to work, but I'll bug her to come along to one of the after-parties or something if she's not off interstate or whatever...
They're 5Zigen GN+ in 18x9.5 +12's with 245 45's slightly stretched.
Thought they'd be around that
I really want to get new wheels, the ones I want are that exact size too
Looks good.
man that yellow is awesome!
Here's my stag now with new wheels thanks to too_much_boost on the forums.
1404638_10151863289248819_183335079_o.jp
wheels need a tidy up around the lips but will get to that later.
The wheel look good on your car.
thanks Sabbai
yeah pipster they are great sizes, they poke a bit, wouldn't be able to run "proper" fitting tyres and a decent sidewall size. Rears fit great, even towed a car on them this weekend and went fine. The fronts need the lips rolled as they scrub at the moment but nothing crazy.
sign up with photobucket and upload the photos there
then copy the link that has the [ i m g ] ____________ [ / img ] around it and past it into your post
as for coilovers BC are popular here, reasonable price, rebuildable, handle well and ride well (i don't own them, just what i've heard other ppl say)
r33 gtr will fit the front and r33 gtst will fit in the back (assuming auto)
$1300 will get you a set of new bc's
the r33 gtr/gtst combo isn't ideal as they aren't suited to the extra weight in the rear but would be the cheapest option i guess
    • Nope, but they are definitely one of the default choices. Well established.
    • Has anyone used > https://performancecoating.com.au/
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
