I dont know, I am undecided but as far as it looks to me,
- behind the rear door its too short, but the doors look OK.
- the roof only has 1 sunroof no 2
- JP normally make kits for cars like cimas, celsiors, centuries, glorias etc. VIP's not wagons.
- Proportions look f**ked up
Holy shit though!!, check out that interior, that deep, deep paint and those wheels - they rock. Might not be a Stagea, but as a fellow waggoneer, I dips me lid. :thumbsup:
Wholy Crap Nick yours is High!! No offense but MAN you could drive that thing along the beach on fraiser!
But mmMMmmMMmm love that dark green colour, that and the dark blue, like SK's, bloody nice!!
About that VIP stagea -
guys its a junction produce kit on a toyota crown wagon... those are factory up-spec crown headlights (with the chrome backgrounds) and front end, not S1 stagea... compare the size of the main headlight to the amber fog light - with the stageas there is a much bigger difference. look at the bonnet and shape of the grille, not stagea at all. The whole headlight is the wrong shape, hey.
that car is pretty well stock except for a lip extension and ride height, im pretty sure. Oh, and BMW Z3 guard vents.
Saw these in japan. Save for some mercs, this would be the finest waggin you could ever want to be seen in. Except for all of our own little bits of work in progress...
Speaking of work in progress... heres mine!
cant wait to get rid of some height... will be at the local car show 26th august. will have the kit from chris (AMS) by then, which means i can get the exhaust done, finally get one of SK's whiteline kits. Then, the scissor doors, and its DONE!!
Edited by qikstagea
nice stageas guys and contragulations mcnamg, welcome to the ever growing wa stagea club :sick:
we got 3 silver ones now on the forums in perth :D
6 stageas cruisin in perth will be sweet when we all get sorted out >_<
Thanks its been a long time coming for me but I cant wait to go crusing in the beast.
Will be cool to to go on a cruise and line the three silver stags up together for a few happy snaps thats provided that mr gtst doesnt mind us taking his mrs for a stagea threesome :D j/k
Yeah I know, I did a quick measure one day and it was 400mm from wheel centre to guard, so it neads AT LEAST 2 inches (~50mm) drop. Problem is, I have a sneaking suspiscioun that my second turbo might be on its way out, so the SK suspension will have to wait a bit longer again...
When I decided the Stagea was the car for me, it was always going to be either dark green, dark blue (like SK's) or dark red (like Chris' old car).
A couple of pictures of mine at a local skyline owners meet - there was a nice S15 there too - mine was the only car there with unicorns - still a very rare sight in the UK - also notice the sunshine!
AND yes I know mine needs dropping by about a foot too! Before you guys mention it - it's on the list :)
Here's mine :thumbsup:
Pretty much stock - got a shift kit installed today tho!! I'd highly recommend it to anyone who has an auto!
Didn't go overboard on shift harshness - so the gear changes are still very smooth (dont notice 3rd to 4th change) but very instantaneous!! yay!!
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
