here's a couple of my stag at Pt Broughton new years day 2009. She towed the 1800kg van with ease 15.8L / 100km and 17.8/100 on the way home with a huge head wind.
Bloody Hell Dan! I hope you didn't encounter any speed bumps along the way.
That 1800kg's definitely puts a strain on your rear suspension.
Nice towball setup though :D
Who did the fabrication and install?
Nice towball setup though :blush:
I built the bar from a modified magna wagon setup, Was a pretty big job to get adequite fixings on the M35 chassis rails, wheel well & back panel. The entire setup has about 20 grade 8.8 bolts attaching it. This setup is not rated as such but from my background of electrical and structural engineering i know that the bar is not the weakest link. I am more woried anout the ally sub frame, where other have seen cracking.
The car needs some air bags for towing the van as it sits pretty low and hopefully I can get these installed before my next trip.
Overall it is a good tow car, Very happy with my stag :blink:
side skirts only sitting on hence the gap at the front, just a quick test fit of the rims from my other car and now i think they are staying for good :P 18x10+20 offsets with 235 tyres, they sit real nice actually, the rear needs to be lowered abit more before i post a pic of that.
Edited by unique1
Man that looks awesome.
Do you reckon you will get any rear rubbing with rims that wide? I am about to fit rims on my car and I would love to fit a set of fat alloys like that.
side skirts only sitting on hence the gap at the front, just a quick test fit of the rims from my other car and now i think they are staying for good :D 18x10+20 offsets with 235 tyres, they sit real nice actually, the rear needs to be lowered abit more before i post a pic of that.
the rear offset is pretty aggressive compared to fronts, i think it shall tuck the tyre in the gaurd but the rim will stick out, hence the reason for 235 tyres so they stretch abit, this is a pic of the rear but its not low at all so when lower it will tuck in abit more. I have the car on the brick trying to get it to lower down abit but it didnt do much. the front rim on in the pic is just a 33 gtr rim.
I wont be driving the car with these on for a while yet so cant comment on scrubing etc until i test them.
Edited by unique1
^^^ you'll be right when you drop it a little, you'll gain some camber and she'll be apples - beware of inner clearance though as you'll be mighty close to the shock
here's my rears that sit the same as yours, just rear end slammed
good to see another stag with mint wheel fitment
hey mate nice to see another good lookin yellow stag, I'm gettin some 18x8's on next week with an offset of +20 so ill chuck up some pics when they are on,
any chance of a side on pic of your car so i can see the mags better? what brand are they by the way?
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
