  • 2 months later...
hasn't been a meet for a while.. last one I missed anyhow! im sure the guys would be keen at some stage to organise one :P
p.s. mine needs a scrub too.. damn this spring rain!!! >.<
Edited by atomaly
  atomaly said:
hasn't been a meet for a while.. last one I missed anyhow! im sure the guys would be keen at some stage to organise one :ermm:
Mine is a dirty ho too. :P
I was trying to organise a Stagea Dyno day, dont want it too big but that would make a great Melbourne meet... Have to see if the owner is interested yet.
awesome, sounds good - maybe once the weather gets a bit fairer - although they have said it will be a wet spring, which is fvcked - so over winter.
and no fun at all for you with a black car!! i'm loving white already, so easy to keep clean, just pulled into the car wash this morning - $1 in the high pressure washer, sprayed off the dirt and its back to new!!
  JDM_Spirit said:
A couple of quick snaps I took a few months back.
looking good mate
whats the specs on the front mount? its pretty much exactly what i'm looking for
have to hack up the front bar/reo much?
  pipster11 said:
looking good mate
Hey, thanks!
Cooler is abit of a custom item. If you look at the where the Inlet and Outlet is there's a weld separating them them. When I first purchased the cooler I got it home and had a closer look. it was more or less a Single tank. I figured Air will flow the route with the least amount of resistance, therefore rendering the core useless. So we removed the tank and cut it in half and welded in a plate that would divide the tank into 2x. Pressure tested and all.
Only down side to this design is when used on Big HP Applications there is almost guaranteed Boost Drop as the air would be cooled twice. No worries for a nimble Stagea :)
Reo copped the usual chop. As I mounted the cooler as low as possible to allow as much air exposure as possible. But I did a neat job with enough room to run a piece of Vac Hose along it to prevent any such rubbing. Also managed to retain all the Under Body plastics.
i would be up for a stagea meet sometime..dyno day you just want to show us how much power your car makes ..you win
But mine is only a little turbo, its only the fuel... I seem to remember you at one of the RE days talking about ecu's and turbo's. Arent you interested anymore?
Funny, as an M35 owner I used to look up to you c34 guys in awe at the power you could make with a quick chip and tune, after a lot of hard work I got there eventually. Now I want to help all the other guys...
  JDM_Spirit said:
Hey, thanks!
i might have to get you to help me out over summer, its one of the many things that is on the shopping list when i get back
yeh got the nistune done but nothing else atm lack of funds next fmic then look into high flow turbo its a slow process but will happen
  • 4 weeks later...
The family runner, finally got to take some pics.
not many mods, but have replaced the exhaust with a blitz system,
meisters, new ebc and some other stuff.
It took us to exmouth and back to perth nicely. [sans the ol manifold studs snapping]
has the RS steering wheel, and the whole family LOVES IT!
Currently on tein lowered springs, does need moar low tho. :(
give us a shout if you see it about! :blush:
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
    • As above, replace as many as you can afford. If anything, due to old age.
