Now I got her some new shoes heres my girl -
just got to get her out of the clouds a bit.....
that ride height doesn't look too bad
get a dayz front bar and it will look even better :D (will look exactly like mine)
pic of the stag now she is coming along just got to wire emanage ultimate in, got it friday and injectors and tune all else done well for this stage any way :thumbsup:
Edited by 4bidn1
Looking great guys :cheers: Whose doing your emanage tune?
mine were about $89 trade from sprints cant remember brand but they are adr approved. no probs at all except if the control box gets too hot like on a 40 degree day like today with the box mounted in engine bay they turn off so if i relocate box into cabin no probs, had them about 3 months will find out brand for you
4bidn1, any info on your LED DRL's??
i've had hit and miss experience with the cheap ebay ones, not sure i want to fork out on the super expensive hella dayline's...
I've posted these up in a seperate thread before but thought I may as well put them here aswell.
Wheels aren't mine, 18x9.5 +18 all round, I think I need 19" instead. (GT-Cs or something along those lines)
Nice pics man. I like the clear indicators on the front. The rear of your car is different to mine, as I have different brake and indicator lights and a chrome piece at the end of the brake lights either side of the number plates.
I will throw some pics up of mine sometime today to show ya :thumbsup:
sounds like you have series 2 lights
here is my stagea and my other toy, the old and the new, the fast and the slow. my tastes couldn't be further apart.
hey man, I'm gonna be up around the 10th-13th of feb, should catch up and go for a cruise or somethin :)
And anyone else in Adelaide who's interested? :)
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
