i gotta say i think thats one of the nicer stages ive seen...
love the yellow. mustve opted for the "chrome me up laddy" pack. chrome strips up the doors, very celsior. and chrome windscreen squirters etc. If only it were black... wouldve made a nice start for the first aussie VIP Stagea.
Is it a DAYZ jobbie?
you never know - not all dayz car got the full option. You can opt out of the leather seats if you want.
Its a DAYZ kit, i believe. But weve seen lots of dayz badged cars that simply had selections from the dayz lineup. Id say this might be one.
tazgtr, saw in photos Tassie number plates. Where in Tas are you? Been hanging to meet some fellow Satgea owners and do a bit of a photo shoot. We're in Launnie. Your dad has a sweet ride, love the yellow :happy:
get some slimlines looser! they were only like 25$ more at rego time!
ps... you bastard and your nice beach living house!
Hehe, I know, must get around to ordering those... I just want one on the front though, the rear slot would look a little empty I think...
P.S. I thought you were almost going to make it down in the last week or two, next time!
Cheers
Luke
looks awesome luke, gotta love the black paint
Thanks Andy, gotta love washing your car if it is black though... I don't mind so it's good, and people get to ask "what's that black thing your driving?"
Hmm you dont happen to travel south on the Mitchell freeway in peak hour by chance??? I reckon I see you every now and then stuck in peak hour traffic heading into the city in the mornings :laugh:
Thanks Kirstie but it doesn't always look that shiny
Yeah I travel down Mitchell Fwy every weekday morning between 8:30 and 9:00 on the way to work. Don't see any Stageas though despite looking.
You drive or a train commuter?
Cheers, Al
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
