i wasnt implying i was a paramedic, i was implying that i was using the area as a loading bay, as i was there after hours.
hurry up and get off your period lol
Car being black and all!.....maybe a carrying around the dead is a better option for you than pretending to be a paramedic!!!!!
I know that, but since you are parking where the paramedics would park for an emergency, perhaps you should start moonlighting as one?
Here, with this addition to your car, you might be able to get away with pretending to be a paramedic!
http://page21.auctions.yahoo.co.jp/jp/auction/j137109709
Edited by iamhe77
nice.....I like it!!!
Cheers big ears... I like it too. Luckily so dose the missus.
The pictures don't really do it justice.
Your AR-X is just right too. I allready had the GTC's, otherwise I would have gone black on black with some R34 GTR rims.
Cheers
Justin
Here's a couple of shots of my S2...
All my skylines are black, so this fitt the bill nicely. And I love the black leather!
Cheers
Justin
Looks nice!
Behold!
more here.
Wow! "real" drifting. finally! lol
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
    • You need to buy a Saab Matt, ours had a button that turned all the dash lights off. Any decent aftermarket dash has sufficient brightness control and a headlight input for day/night settings. None of which probably helps OP
    • Yeah thanks...i thought it would be alot more i dont know 馃槃 I saw some videos on converting push/pull and it seems you need to "drill" the hole for slave(master) cylinder and buy some converter kit. On that front yoke clip i did not even know that is a thing and i need to source that(custom shops do not do that?) But anyway thank you for the info
    • Not the headlight. It's the DRL that serves double duty as white and amber. Would be the easiest way to make it happen, if fitting a BCM was in any way an easy thing. Otherwise you'd do it with some relay logic and/or maybe some diodes.
    • Would require a very smart body control module which these cars are about 20 years to old to have
