It will have a watermark, just a quick low res pic the photographer sent through. There is a possibility it will end up in a mag...
Jun at work, this is my attempt at photography with my new Nikon V1. :)
Can't wait to see the whole shoot.
Below is my attempt with my Nikon D3100....low res shot linked for web ofcourse.
Welcome Daniel.
Full Giala kit? (the rear looks like it could be factory aero from that angle.
Ive got no idea what kits on it, either did the guy i got it from, I've never seen a kit like it and i thought it looked pretty cool... but from what your saying it does look like the gialla kit, unsure what the rear bar is ill post another pic this arvo :D
Welcome Josh! Where are you based in Adelaide? I think I've seen that around...
I'm from the Barossa.
Looks nice Josh!
What wheel size are you running?
Cheers dude, running 18x9.5 +12 Rota Grid R's all round.
Fellow Stagea owner from scotland :D
Welcome Dave. Nice example you have there. Enjoy your summer? Must have got up to a blistering 18 deg, lol. Good turbo driving weather tho :yes:
    • Well it does have a motor with the same DNA as an Accord V6 motor. The J30A is a successor to the Tiger rice cooker C32A motor found in those cars.
    • FD RX7 I would probably marry if legal R32 GTR is toughest NSX looks like it's made from leftover Prelude and Accord bits
    • When going to a suspension shop should I send them the default nissan settings or just let them do their own thing? I ask this because I have aftermarket rear camber arms and my car is lowered a bit (front end is basically stock after I change to those nismo bushes)
    • Ok sounds good, thanks for your help. Hopefully if I end up changing it to the nismo bushes I don't get that veering issue. I don't think there's a point in lubing up these bushes again. Weird that it it makes just as much noise with all the grease inside it versus without grease prior to removal. Bizarre.
    • Yeah, you don't need camber bushes on stock arms to make a car drive straight unless it's got another problem. F'rigsample, slide the thing into a kerb, bend the front subframe mounts a little....subframe is now twisted, shifted or otherwise in the wrong spot...and you need to do funky stuff with the wheel alignment to get it to drive straight. Maybe a little more caster on one side, or a little more camber. FWIW, I can have my camber off side to side by a half a degree or more, and either way, so more one side, or more on the other, and the car doesn't really want to pull to one side. It will definitely ride road camber differently, and want to track uphill (ie, towards the centreline when on the LHS of a normal crowned piece of road, like it should) or want to roll downhill (which it really shouldn't). But on fairly flat road surfaces, like the middle of a 3 or 4 lane motorway, a half a degree either way doesn't make a lot of difference. I sometimes do quite a few miles with my wheel alignment messed up, because I don't always get a chance to set it right again after a serious dismantling, before I have to drive it to work again. Like, a whole week's worth of daily shuffle.
