your girlfriends cars are nicer than yours!..lmao, both look tuff
cheers
darren
Baaa haaa that's gold , nice way to spend 2.5k on wheels ! Saw them for sale not long ago.
Just bought a stag, hopefully pick it up this weekend. Wanted one of these ever since i saw my first one.
RS FOUR S
basically stock, spitfire coilpacks and a dump pipe. also getting some racing gear coilovers with it.
Needs some things pretty badly, not sure what to do first.
Exhaust is stock, not sure whether to import one or get one made locally.
Wheels , I'm thinking bronze xd9's. 18x9 +20s
Either a front mount or upgrade the sidemount.
all the info on here has been really helpful.
cheers
  • Like 1
so car is all registered in victoria and have the same issue with number plates as before - bent into the recess!
anyone got any ideas for that rubbish look on the front end of a series one - sorry for being slightly off topic :)
photo's from Dragphotos at willowbank finally purchased them
Are you coming on the Newcastle putty rd cruze? http://www.skylinesaustralia.com/forums/topic/427337-sau-newcastle-putty-rd-syd-meet-up-21st-july/
It would be good to have another 260rs coming , I know another fellow who just bought one he might be coming as well
They arnt my pics mate and they arnt good enough for me to warrant paying for them. So wording stays haha. Hopefully next time we might be able to have some along to take photos that dont have words over them haha
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
    • Wow. Pissy much? You on a mission to find old posts to argue with, or is this legitimately just because you're 5 years into a 1 day job?
