Hi Everyone,
My friend has a R33 with a 3inch exhaust and runs 12 pound on it. He hollowed out his cat and installed a dump pipe on the weekend. Said it pulls heaps harder but at 4000-5000 it seems to hold and then kicks in again. Anyone think they know why and have any suggestions to avoid this.
He has no electronic boost controller or FMIC either. any help would be appreciated.
hollowed out cats create more back pressure than a normal cat..proven
i doubt its the dump pipe.
What drugs are you tripping on?
Proven that hollow is less backpressure... if anything.
12psi stock cooler is just silly behaviour. Its probably 15psi+ before the cooler and i'd say the turbo is going to die very shortly if he keeps that up
The problem is this, its just Rich & Retard mode. Use the search button. Common problem on a boosted skyline with a stock ECU
how does that worK ??
because the air instead of passing straight through, swirls around in the now empty cat, causing turbulance and slowing the air flow through it..
better to get a cat replacement pipe made up, or smashing a piece of pipe the right dia through the old hollowed out cat, so its basically a pieve of pipe inside and not a hollow chamber..
Hi Everyone,
ECU rich and retard mapping due to excessive airflow as sensed by the AFM.
:glare: cheers :laugh:
PS, write 50 times.........
There is no such thing as boost cut
when it kicks in it certainly feels like a boost cut, cause it dies completely then kicks back in.
is it a sudden stop start, or a flat spot where acceleration slows for a bit. if it is a sudden cut out then it is 'boost cut'. if it is just a slow spot then it could be the cams changing over. there is a thread on it somewhere on here, and how you can change when it does it slightly with an aftermarket ecu.
Boost cut = 2 words “boost” and “cut”
Boost = The R33GTST ECU has no idea what boost the engine is receiving, it doesn’t do anything about boost, it doesn’t care.
Cut = reduce to zero
Reduce what to zero?
Fuel, nope the ECU doesn’t do that
Ignition, nope the ECU doesn’t do that either.
What you are describing is excessive airflow as sensed by the AFM. When the ECU sees excessive airflow for the rpm and throttle opening it moves to Rich and Retarded mapping. This is done to protect the engine from what the ECU thinks are faulty sensor reading. Either the TPS or the rpm sensor or the AFM (or all three) are reading incorrectly based on the ECU’s programming.
Note the words used “When the ECU sees excessive airflow for the rpm and throttle opening its moves to rich and retarded mapping.” That is why you get a drop in power (R&R mapping) just after the boost has peaked. This goes on for a few hundred RPM, then the sensor readings (the TPS, rpm sensor and AFM) start to line up again. So the ECU returns to more normal (non R&R) mapping.
This is even more proof that there is no such thing as “boost cut”, otherwise it would stay “cut” for as long as the boost was high. But it doesn’t.
Repeat after me;
There is no such thing as boost cut………….
:D cheers :wub:
i call it boost cut cause its easier than saying rich and retard mode.
slightly off subject, does the stock ecu have a map sensor? there is a box in the back corner of the engine bay on the drivers side with a vacuum hose hooked up, and wires coming out the other end. what is it for?
Edited by mad082
in the name of correct terminology, and correct information on the forum.
Its Rich and Retard.
There is no point calling it boost cut... if is not boost cut.
That is incorrect. The forums are hear as a source of accurate information to help those that are having problems or need extra help.
Are you an enthusiast? Do you even care about the accuracy of your posts?
well everyone calls the skylines with the active diff a 'GTS-T with an active lsd' when they are really called a 'LSTS'. and my source for that is an article in a HPI mag (as well as various websites i found in japanese and translated).
and does it really matter if it gets called boost cut, or rich and retard mode? i doubt that there is someone out there who will read this and think 'i couldn't get rid of my boost cut without changing my ecu, but now that i know its only rich and retard mode i can fix that no worries'.
at the end of the day it is a different name for the same thing. the are plenty of things on this site going by the wrong name.
Edited by mad082
The problem is when someone is told it is a “boost cut” problem the first thing they think is there is some hard and fast boost limit that they can’t exceed. Then we get silly stuff like;
1. I have been told I can run 1 bar before I will get “boost cut”, is that OK?
2. My mate runs 12 psi and doesn’t get “boost cut” and I run 11 psi and get “boost cut”, why ?
3. Something is wrong with my engine I get “boost cut” at 10 psi ?
4. GTR’s don’t get "boost cut" until 1.1 bar, so why do GTST’s get "boost cut" at 11 psi ?
and 100 more equally wrong questions per week, every week.
The reality is we need to get people on SAU talking about excessive airflow, boost is irrelevant. So if the regular posters don’t use “boost cut” and use the correct terminology then eventually we won’t have to spend time writing explanations as to what it really is and why boost is irelevant
:rofl: cheers :P
Edited by Sydneykid
That doesn't answer my question - the post read:
"hollowed out cats create more back pressure than a normal cat..proven"
Which is rubbish.
I can prove you you that with a (brand new catco 3") cat - my skyline made 289rwkw - with a elcheapo compliance cat hollowed out - it made 330rwkw - (only under test conditions on the dyno of course).
:D cheers :laugh:
Totally agree as there are ECU's which "boost cut" (subaru, ford,toyota) and there are ECU's which reach a predefined "airflow limit" usually vs rpm (mitsubishi, nissan,GM).
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
