1. I have been told I can run 1 bar before I will get “boost cut”, is that OK?
2. My mate runs 12 psi and doesn’t get “boost cut” and I run 11 psi and get “boost cut”, why ?
3. Something is wrong with my engine I get “boost cut” at 10 psi ?
4. GTR’s don’t get "boost cut" until 1.1 bar, so why do GTST’s get "boost cut" at 11 psi ?
so instead of all those you will have the same questions, but with 'rich and retard mode' instead of 'boost cut'. no matter what term you use people will still keep asking the questions.
The problem is when someone is told it is a “boost cut” problem the first thing they think is there is some hard and fast boost limit that they can’t exceed
it is a limit that they can't exceed. on that particular car, whatever boost they are at when the r&r mode kicks in, that is the limit as to what they can run. sure they could run a higher boost, but it will cut out earlier. there is no way they can get around it without a fuel cut defender or an ecu upgrade.
also a lot of you make it sound like it just gets sluggish when it happens. it is a harsh stop in power. it is literally as if someone has turned the key off, then immediately turns it back on, and in my case results in wheelspin in the lower gears if i don't lift of the gas quick enough. then it keeps pulling up through the rev range about as hard as usual.
Hey Everyone,
Thanks for your help. So I guess it's a re-map for my friend. Much appreciated
R33’s can’t get REMAPS (easily)
and
is it a sudden stop start, or a flat spot where acceleration slows for a bit. if it is a sudden cut out then it is 'boost cut'. if it is just a slow spot then it could be the cams changing over. there is a thread on it somewhere on here, and how you can change when it does it slightly with an aftermarket ecu.
Maybe you missed it..
There is no such thing as boost cut
Maybe you missed it
maybe you missed my inverted commas. also refering to it as boost cut isn't really any different to giving someone a nick name. if someones name is james and i call them jimmy, i'm not calling him the right name, but everyone would still know who i'm talking about.
That’s exactly the problem, think about this question;
I had the standard turbo at 10 psi with no “boost cut”, why do I get “boost cut” at 10 psi with my new (larger) turbo?
Well that’ because it’s not boost that is the problem, it is excessive airflow. The new (larger) turbo flows more air at 10 psi than the standard turbo. The only fix is an AFM voltage bender, rechip (if possible) or aftermarket ECU.
But everyone told me it was “boost cut”, so I spent all my money buying a new turbo to I could make more power at the same boost and not get “boost cut”. I don’t have any money left to buy an ECU…………..
Do a search I will bet you find 50 posts with exactly that problem of misunderstanding. Which is simply avoided by using the correct terminology.
:ermm: cheers :(
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
