I Guys & Gals
Put in stereo (& alarm) on weekend in my S2 R33...Its all good except the DIN i used was not a nissan one but a universal & basically its a cheap piece of shite which does not fit (gaps etc)
Anyhow did a search & apparently the genuine nissan pulsar one fits in perfectly & is availble for $30-$35 which sounds good to me but then i read that a toyota one is exactly the same & is only $10...Is this true & if so which model toyota DIN should i buy?
Also i have an alpine 9831 MP3 HU & like others have encountered the surround does not fit...how have people gotten around this & is the surround supposed to sit behind the actual dash or in front?
Cheers
https://www.sau.com.au/forums/topic/123749-din-pocket-hu-surround/
If i were you i would just go to nissan and get a genuine one..
otherwise you will end up with a $10 din that doesnt even fit..
otherwise try powerplay imports
they usually give sau members good deals
http://www.powerplayimports.com/
Give them a ring.. but they wont be open til tues due to the powerplay track day..
hope that helps..
I had no problems fitting the 9831 into my car.
Follow this guide on the HU surround. http://r33stereo.groovesystems.net/
You have to drill new holes. I have the same HU as in the guide, but i cbf'ed drilling the holes so I just removed the plastic surround and didnt use it.
As for the poket din, line it up and use eletrical tape to secure it or use cable ties. The one I used was a generic one and it fited perfectly after tieing it up with tape.
Do you have a pic of your pocket?
You can buy the pocket off me for $10? Where abouts are ya?
Yea i have that guide but i wanted the surround to sit on outside of the dash, not behind like in the guide where he has pushed his HU back so that it all fits behind
Re the pocket thanks but no thanks i would rather one that actually fits correctly rather than taping it etc
Thanks anyhow
I have used the guide. My surround sits nicely behind the fascia, can post a pic up when I go home for lunch. When I first bought the car the owner had just upgraded from the stock stereo and had the surround on the outside, it looked like crap. I sold that one and upgraded to a Nakamichi.
As for the Din pocket, I went to an Audio store and asked if they had something that would fit, ironically they had fitted a system to a brand new Nissan Navara earlier and gave it to me for $5. Perhaps you could try asking around.
Edit: Here you go. Please excuse the layer of dust on my interior
Edited by MintR33
It does look good behind...all nice & flat...ok might consider doing it that way then
would the navara DIN be the same as a pulsar one?
Thanks
nissan pockets are nissan pockets. they all come from the same bin.
in regard to the toyota one - NOPE! the nissan one will boilt straight in. I usually keep them on hand for $28 (out currently.)
If you havent heard of it then chances are you haven't heard of alot of these brands: Click (go to Exotica)
Basically Nakamichi is a high end SQ brand that became famous in the 80's (but has been around since the 40's) for innovating alot of the cassette deck technology of the time. These day's they are largely overlooked, mainly because they are quite expensive and not widely available. About 99% of Nak's R&D goes into making really high fidelity sound reproduction, and as such the appearance of thier units is kept minamalistic and direcected at complimenting the rest of the vehicle's interior (hence the reason for no bling looking screens or chrome buttons).
At the time of purchase (2004) my h/u was retailing at approx $1600 from memory. I think you can buy them now for around $800, but my model does not play MP3.
Here's one of their new products that looks extreemly nice, its their new indash DVD/TV tuner:
For more info visit the website.
http://www.nakamichi.com/
Edited by MintR33
Do you sell Nak stuff Chris?
If so do you know if you are able to get hold of Nakamichi SP-C6500 splits?
I do but not a lot of it.
I can do decks but not speakers (I'll check though.)
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
