Hi guys,
As you may know from other threads i am looking to get some 18" starcorp Impuls rims with falken 451/2 tyres. Two people recently have brought up the fact i will have wider rear tyres and say this is not a good idea and will create alot of understeer.... where as i thought it would give me better grip? Especially with decent tyres...?
I know the rims arent the best quality, but its just a street car, not for racing. I dont see why they wouldnt be adequat as others on here have them and say they are ok.
https://www.sau.com.au/forums/topic/123752-wider-rear-tyres/
I have those wheels and wider rubber at the back (235 vs 265's). Understeer is only a problem if you have stock suspension and take a poor line into a corner. Skylines are a heavy car and don't like to dive into corners in the same fashion as a lighter car would, a smoother trajectory (more like slow in fast out) and better suspension will help. I have the height adjustable bilstiens from the group buy, they did wonders, now for some sway bars :rofl:.
Well im not going to be a hero racing it on a track, so i think grip is more important than a little bit of understeer which shouldnt be too relevent for normal driving. Not like im gonna go thrashing around corners.
If you're not planning on being a hero on the track, understeer is a good thing. Understeer is safer than oversteer for a novice to middling driver, which is why practically every OEM tunes their cars to understeer when approaching the limit.
I noticed from your other threads that you're going for looks after some kind of major performance benefit, and cars with massive rear tyres always look hot. So don't worry about it. As long as your fronts aren't too narrow, in your case its not a major problem to have a wider rear.
I've gone from a staggered tyre size to the same all-round, but then I do like thrashing it around corners. :(
(and, as an aside, when my current street tyres wear out I'll be returning to a staggered size for the phat looks, yo)
I had noticed more understeer when I went to a staggered set of rims (8inch front 9inch rear) but this was only when pushing it very hard on motokhana style events with really tight corners (R33 GTSt's do understeer horrribly in these kind of events)... for everyday driving you won't notice it
BTW adjustable swaybars helped me tune out the understeer simply by tightening the rear a couple of notches... so I have the added grip in a straight line that wider tires will give plus its not pushing like a smack dealer anymore!
I'm with Nick, R33's in general dislike tight corners where sudden changes of direction induces nose diving. This can be tuned out but it is far easier to deal with understeer as opposed to massive oversteer, which while fun, easily gets out of hand much faster. You can get super duper suspension setup and sway bars etc to deal with it, but you've said on numerous occassions that you want a compliant ride which means that your suspension mods will be a bit tamer and as such you'll get a little understeer. I came from a FWD car so it's natural for me to deal with, go have a trash late at night on a deserted section of road to get a feel for it if you're uncertain.
Also, in the time you've spent posting here and PM'ing me, you could've tested all this for yourself :( Just buy the damn wheels and post pics!
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
