Hopefully some quick n Easy Questions for the techo's on the site. I have searched the site topics for answers but with no luck. I drive and learn bits n peices as I go along so If my questions are simple it indicates my knowledge :glare:
My RB26 engine has just been rebuilt with JE forged Pistons, Eagle rods and Tomei Pon Cams (260 degrees/9.15 lift) in/ex.
Q1. I'd like to know what the cylinder compression should be?
The reason being I have had two readings from different garages 85psi (all 6) and 120psi accross all 6.
Prior to the rebuild, with the stock internals, 155 accross all 6. Could my bad battery cause the inconsitency's. I am advised the Pon Cams do make a difference - what should the readings be?
Q2. Spark Plug in cylinder 1 had oil on it. 2-6 are fould. Is this part n parcel in the first few hundred Km's? Could it be from the front turbo if it has been stuffed or the run in tune?
My engine has about 450kms on it now.
Q3. My R34 N1 Turbs (3 months old) were fine prior to the rebuild. After the R&R now #1 (one) makes noises when it was first fired up and ongoing, What could be the cause or issue? Stored for 15 months while the rebuild was happening. (whinning zzzzzzzzzzzzz sound).
Q4. Should there be lots of blow bye and smoke occuring when it was initially started/ongoing? If not what is the possible cause/issue. The oil catch can was left in place during the R/R and was fairly full, but has since been emptied. Smoke has reduced somewhat but what/how do you test or rectify blow bye? What does it indicate?
Q5. I have heaps of black spots showing on the rear of the car, and black dust all over my garage floor, out the exhaust ? Part of the bedding in or is it just tuning ? Heaps of fuely smells while driving!
Q6. The AF mixture was initially set to 14.7:1 (lean?). on the PFC, Is this OK? Z32 AFM's.
It has been changed by a different tuner but apparently is now pinging (knock). Now being re-tuned to suit the AFM's.
Q7. The Aux air valve is blocked somehow, what is the effect ? Can it be clearaed or is a new one required?
Q8. Finally, Is it common to have noticable traces of fuel in your oil at the first oil change ?
Thanks in advance for your experiences/knowledge.
https://www.sau.com.au/forums/topic/123757-8-questions-on-rb26dett-rebuild/
6. AFR is not related to ecu type or model, its related to the tune and how the tuner has tuned it. pinging is usually related to much advanced ignition, but can be affected by running too lean also. 14.7 is ok for cruise and ideal but for max load and during boost build its too lean
In regard to your compression test, i am unsure if it is normal but i bought my car that already was built with forged pistons and a 1.2mm head gasket, it also has tomei cams that are around 260 degree (i dont know till i pull covers off exact specs arnt written on the recipts) but i also comp tested at 120psi.
thanks Alex - *breaths easy* thats good news to me.
If its blowing oil smoke *not condensation* when starting or after sitting idling and giving it a quick rev its a sign of valve stem seals, it is very possible and has been known for them to be damaged when during a head reco process.
My plugs were clean and the oil never smelt like fuel. I did multiple oil/filter changes within the first 1000kms.
It did use a little oil until around 4,000km's after that it hasn't used a drop, I've now done 40,000km's.
the fuel in the oil might be from running excessively rich or one cylinder not firing and the fuel is washing bores and going past the rings into the sump oil.
my comp test after only 500km with 272/11.35mm cams was 155psi so that under 100psi readings sound wayyy off.
oil on one plug shows its not firing from memory
thats my opinion, what do others think of those ideas?
I have done around 7000km's on my newly built engine, using 87mm CP Pistons and Tomei cams, and a recent compression test showed ~180psi across all 6 cylinders and a leakdown figure of 6-7% across all 6.
Can I ask who built and tuned your engine?
Have you done a leak down test?
hey sinista32,
i rebuilt my engine not long ago pretty well the same. je pistons 260 poncams etc. because piston 5 and 6 ring lands decided to melt. bad blow by before rebuild
i had a really bad problem after the rebuild of blowing blue smoke when idling, cruising but not boosting.
after about 1000kms i finally worked out that in the cam covers there are filters before the pcv outlets. mine were blocked and because the pressure couldnt go anywhere it made its way into the combustion chamber, hence the blue smoke,
i removed the cam covers and soaked the filters in kero,
havent had a problem since.
it was heaps embarrasing when you have just rebuilt your motor and its blowing smoke all over the place...
let me know if this helps
cheers
Jeremy
Edited by DVS32R
Thanks for replying guys
Cruise and Blitz - Thats what worried me on #1 cylinder, possible fuel washing the bore/s. It's highly unlikely but it wasnt worth risking.
I think a leak down test is in order.
180 PSI That's good - I'm not certain what it should be but I note one post quoting 120 from GTR1993. I expect it should increase over the run in process. However, Who would be the authority on whats the norm?
DVS - I'll get the filters out of the cam covers and cleaned. I might have the same issue. Good advice. BTW as your build is very similar Jerry whats your compression readings ? (few cars up here with the Hektic stickers on)
Cheers
Richard
This is totally hypothetical so i dont know if this it true:
When you go to a larger duration camshaft low end performance suffer because of the increased overlap (i know this doesnt have to be true but generally increased duration has increased overlap) Anyway, with increased duration low rpm performance suffers, now cranking a cut is very low rpm only few 100 rpm, does this mean that there will be a lower PSI reading as increased overlap is bleeding off cylinder compression??
when i had the blue smoke issue, i carried out a compression test with stock cams. it was 155psi on all 6.
only recently put in the poncams. havent done a comp test yet. has had a few hard dyno sessions. i will do a comp test this weekend if you would like.
are your Je pistons 40 thou oversize?
did the person that built your motor know that je pistons use smaller clearances then most forged pistons.
cheers
ps i dont know what hektic stickers are. i just put hektic on my profile thingy cause i like it.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
