Rb26 In A 32 Gtst
play r 32
 Share
  • Replies 121
Posted Images
Thats good news about the gearbox droo, im hoping for at least 6 months out of it, driving only on weekends.
Sounds like you got you got away with your conversion pretty cheaply redline. Did you do some of the wrok your self to keep costs down? I think the gts4 is easier as well coz you can use the same sump and things like that?
My motor is finally in! all thats left now is wiring in the microtech then its off to the dyno next week! Im so excited i just did a little bit of wee
Cheers frost. nah didnt end up using the fuel reg yet. Gonna see how it goes on the dyno first with the gtr reg.
Thanks Mitchy, the colour of the motor against the yellow i wasnt actualy to keen on when i first saw it, its growig on me but.
The wiring is done nismonewf, the photo is a week old.
I was dreaming. Still no dyno. I cant push the guy though, if I was paying him by the hour the job woulda cost me twice as much. I just got the word he wants it out by friday so now i have a good chance of driving it for the weekend!
I gave Him my car aout 7 weeks ago. The deal was though, because i have a daily driver he would do the job cheaply if he could work on it in between jobs.
Dunno how long it would take if someone worked on flat out.
My car finnally hit the dyno today!
310rwhp. Thats a mild tune to run the motor in, but i think thats still going to feel pretty bloody impressive considering my only previous mod was a pod filter and a cat back exhaust.
It did go as high as 348rwhp on 15 psi but 310 will do for now.
Thanks for everyones advice and interest.
  • 3 weeks later...
i just had a friend of a friend tell me having a RB26 in a R32 GTS-t makes no difference and saying that his R33 GTS25 will still beat it, because of his engine and weight. how funny is that :/
Nice work dude! Has come along very well. How do you find driving it now compared to the previous setup? Suspension will be the key.
It will be interesting to see how long the 20 box lives..! Stash some cash for the expected :)
I have an R32 GTS-4 with a 26 shoved inbetween the strut towers also, flick it into rwd and all she wants to do is dance and shake her booty!! :huh:
Edited by Remix-
 Share
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
