  • Replies 121
Posted Images
Indeed! the engine itself wasn't expensive, neither was the conversion (expensive in time and energy.. RB30 built, fitted and running in a weekend :D).
The expensive parts come now.. need some custom bonnet work, need a tune along with a z32 afm and some bigger injectors.. I can feel this 20 box isn't very happy being behind a 3L now so a 25 box is going to be needed soon O_o
On the funny side.. got the RB25 turbo that I had on my 20 on there.. full boost by 2000rpm and no lag, instant boost! heh even untuned and running like shit it was pulling up a big hill in 5th at 2000rpm.. 3L ftw :D
Our 26 is here in the workshop now , box n twin plate here also .. gone for 34 bellhousing n pulltype ..
Once the new turbos n tomei manifolds arrive we will fit up n drop it in the hole ;)
Be running by christmas :P
Just thought I'd update.. car is now running fine on the chipped ecu from the group buy.. with r&r removed it revs out but, I don't rev it past 5.5-6k or give it much of a hard time till it gets tuned.. 2 weeks away <sigh> :D
flahs once you get a 26 your car will be exactly what i imagined my car to be like when i first started modding, vertex kit and all. Mine was originally black. Somehow i got sidetracked though ? you got the vertical doors hey? :closedeyes:
5500ish for the engine
i would recommend not to get scissor doors as it is a pain to install and there will be cutting in your front fender and plus the gas strut will hit the inside of your fender and you will have a lil ding
Edited by Flash89
hey all im new to your forum but ive done the rb26 into a r33 gtst it was excellent in fact i cant suggest it highly enough its not laggy at all it can paint the roads with black lines whenever you want they rev nice the standard twins exhaust and cooler got me 340 at the wheels :O netted me a 12.20 @116 mph on street tyres i did the conversion myself but when it comes to sumps i just bolted my old rb25det sump on there was a second set of bolt holes on the bottom of the rb26 block i had to grind away part of the oil pickup but that was it. being an r33 i had the rb25 5 speed and that thing is still going strong total cost around 5ish for me i think i used everything from the half cut plus a new clutch and thats about it i think but compared to the rb25 powered r31 ive got my 33 shits all over it my r31 makes similar power on low boost but it would have gotten its ass handed to it by the r33 on the street or the racetrack
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
    • with the car running (runs fine when temp is cold), I unplugged the MAF and the car stalled.  I have already cleaned it a week ago.  I unplugged the O2 sensor from the left side of the vehicle, and the car was still running.  I let it idle for about 5-7 minutes and shut it off, to see if it would restart, and it did not.  It cranks but doesn't start after engine temp gets up to normal range.   I still need to look at the coolant temp sensor, is this one at the top or bottom of the radiator? Or is it one of the sensor threaded into the T-stat housing?
