Guys,
I may have the option to buy the r33 widebodykit and was wanting to know peoples thoughts on this kit and also if anyone has this kit fitted if they are suppose to go on gtst's or gtrs or both in the way of fitment and alignment wiht bolt holes etc
regards
Mushroom
https://www.sau.com.au/forums/topic/123805-kakimoto-bodykit/
we've got the original as the company track car... built by kakimoto (not the copy by skyline imports)... the kit's meant for a GTSt, but can be adapted onto a GTR.
The original uses rear castor to make the wheelbase of the car longer than standard (for race use). The copy was remoulded so the wheels could sit in the factory position without rubbing on the kit.
You'll need 10.5" wide rims for the front and 13" wide for the rears to fill out the guards.
Expect to pay about 5k for having the kit fitted, as if you want to have it done properly you'll need to modify the body so the wheels don't rub, and have the inner guard cut etc. Also blending the rear fender skins into the body requires you to take the original body back to metal, and bonding the fibreglass to it, or risk having it crack in the heat with age.
here's ours...
To my knowledge none of the skyline imports built ones have the Kakimoto wing (which everyone thinks is rice, until you actually sit in the car and realise that you can't see the wing through the back, and is fully adjustable carbon). There's also a carbon splitter for the front, which we've removed because it seems to collect everything on the ground. Also Kakimoto seems to refuse to sell the widebody sized rims to the public, unless you actually have the kit fitted by them.
There still trying to off load that kit eh. Funny what happen's when you ring Mr kakimoto him self, and he makes legal threats to dodgy people about having his kit knocked off.
Nice kit how ever, if you buy it make sure you don’t go cheap on the wheels, it’s what make the kit look complete.
Edited by Nismo_Boy
355.... OMG Ubbbbberrrrrr rubber...
I wonder and shudder as to the cost of name brand tyres... :)
We run Pirelli P-Zero's. $800 a pop
AFAIK there's R32 and R33 kaki widebody kits, but not R34 from memory.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
