hi guys ive recently bought a r33 gts t
im new to these cars and the a lsd light comes on sumtimes for no reason as far as i know can any one help me with this is this a common problem and also are there certain hydraulic pumps and computers to check for the lsd or anything like this any info would be great cheers
https://www.sau.com.au/forums/topic/123814-a-lsd/
Yes skylines can have an A-lsd light.
It means you have an active spec LSD version of the skyline.
Run some searches there's a shipload of info on this site about the A-Lsd.
As for it intermitently turning on. Do you have a power-fc? If you do I strongly suggest you look at the signature of a guy on here called PaulR33 as this is a fault that happens with the A-lsd failing and power fc's, but he's got the cure (read: DIY) to fix the problem.
If you don't have an Power FC.
Perhaps a fault with your abs sensors or the computer itself, or the hydralics, or a lack of fluid?
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2286171
Some Gtst's came with the vspec diff you are very lucky as they are a rare option.
The A-LSD light in the tacho it only comes on if there is a problem. The ECU for the ALSD is in the boot. Does it stay on always or just come on now and then?
Chris
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2286173
Nah, Actually, this site is pretty gay regarding a-lsd. I keep asking about certain things about a-lsd.
No one knows what fluid it uses. no one knows how to bleed the system.
No one actually knows how it performs relative to the normal gtr 2way diff.
Searching will get you info about fully sik people talking about fully sik stuff. but nothing actually useful about the a-lsd.
Like there's info about how people have installed fully sik power fcs into their fully sik skylines to make them fully sik and go quicker.
does someone actually know anything useful about the a-lsd? if so, please post.
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2286188
Check fluid in a space in the boot on the right hand side, you'll see a little canister behind a little clipped on segment.
The fluid it takes is power steering fluid.
As for the microtech, this might be causing the problem, from memory the A-Lsd computer requires a signal from the ECU that aftermarket computers generally don't give and have to be modified to suit.
Here I've run the search for you, check this link out:
http://www.skylinesaustralia.com/forums/in...howtopic=107656
Now I realise that you don't have a power Fc, but the premise behind the solution should be the same for the microtech.
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2297867
hmmmm. i love it when people get credit for my work :
putting it simply.. while driving the light will come on when the wheels slip. (lets you know its working)
if not. you need to aply the tps signal to the a-lsd ecu. just check "moonie" 's topic on a-lsd. i fixed it for her at wsid :dry: with a multimetre and some eletrical tape :)
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2300251
if not. you need to aply the tps signal to the a-lsd ecu. just check "moonie" 's topic on a-lsd. i fixed it for her at wsid :) with a multimetre and some eletrical tape :whistling:
Hey man, apologies, credit where credit's due.
I just remembered following the post about the fault with the A-Lsd (As I have one in my car, but my ecu is still standard), and remember Paul copying it to his link on FAQ on A-Lsd's.
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2300910
how about if someone actually says how to blled the syhstem and what fluid it uses?
There is a bleeder nipple on the right hand side under the car runs along the right hand chassis and is roughly above the diff cradle. Make sure the car is running and bleed out the air from there.
It is difinitley power steer fluid. It will also read low when the car is off! So don't over fill it.
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2301216
cheers for all the info guys i mite attempt to bleed it on the week end there is red oil ontop of another coloured oil like some one said on a previous post in my canister so i mite replace it can anyone tell me a specific type of oil to use and a rough price
cheers guys
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2308992
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
