Hi Guys,
Read an interesting article by APC regarding the use of 3rd gear when producing a dyno report. My last couple of tunes by Bris Tuning have been done in 3rd gear which is frustrating to say the least. When I asked why they used 3rd gear they said it was too much strain on the car and equipment (bullshit) but the result would be the same!!dyno_difference_in_3rd___4th_gear.pdf
Edited by stealth
https://www.sau.com.au/forums/topic/123830-dyno-results-in-3rd-or-4th-gear/
  • Replies 44
Posted Images
Hi Guys,
Dyno runs should be in any gear closest to 1.1 ratio such as 4th in a skyline.5th Gear is overdrive.
Varying on the dyno,The run should never reach over 240 Kms an hour otherwise on a dyno dynamics dyno it hits the electric break and slows the car down,In this case you will need to do the run in 3rd gear. If you have it on shootout mode the ramp rate is automatically set when you chose Shoot 6F,The Gear and tyre Pressures should be entered as well as temperatures of the day.Inlet air temps will also show to prove that the sensor isnt near the extractor manifold reading hi inlet temps giving hi hp readings.
If you load the car in 3rd instead of 4th there will be a little change in hp as it will ramp quicker but nothing more then 40hp just depending. I tested this on my dyno dynamics dyno and only got 5 hp difference
Its good to hear another side of the story.. as always there are so many different solutions for the same result. Its hard for the novice to know who to believe.
Thanks for the input
In 3rd there is generally less load, same as less in 2nd and in 1st
turbo cars often make more power with a higher load as they can build more boost (there is another thread on here about it). so in 3rd gear on the same ramp rate it wouldn't have as much power difference as it would on the highest ramp rate.
what about changing diff gear ratios?
I have tryed this on my car personally and found that there is very little power difference, even when we changed ramp rates from 100 to 150 only a few kW difference.
also the link isnt working for me.
Edited by GTR1993
This is exactly what I have experiened, In third it made 4rwkw less and it was consistent, we did 4 power runs alternating. :D
Sorry guys, dont know why the link isn't working - scanned an article and it has created apdf file which doesn't seem to open.. any hints?
i had my stock R33 dynoed...i was putting on an exhaust the next day, so i spent the cash to see what it was making in stock form, and planned to re dyno it once the exhaust was fitted to see the gain made.
my bog stock R33 made 182rwkw....the dyno operator proceeded to tell me that "you never know whats under tha heat shield...the dyno doesnt lie"
after explaining that its not possible for a car with a 187kw engine to make 182rwkw, i gave up as "i had no idea what magical turbo was under the heatshield on my bog stock R33"
i posted a thread about it when i realised it was ran in 3rd gear, and had mixed responses...mostly people telling me that im wrong, and that the gear doesnt make a difference.
Seems someone has deleted my thread ...dont know why
Hi stealth,
Was this a 4WD Dyno or a 2WD Dyno.?
We have the challenge of running a GTS4 AWD RB20DET car on a Dyno shortly this week, but I'd like to know of some differences between the two as well as the selected gear for the run. Car is an automatic.
Seems a grey area to me about the whole procedure.
Cheers
As already stated the reason for using lower gear is so not to overspeed the dyno, stock to mild cars should have no problems being dynod in top gear, and the same for automatics, if your car does over speed the dyno in top you usually finish top end of tune at the track, which in most cases is what has to be done anyway. usually only get 90% of tune on dyno and clean the rest on the track. as for the power readings, as long as you dyno the car the same way before and after your modifications, you will see an improvement which is what you are looking for.
Dyno run should always be done in 1:1 ratio or 4th gear.
Sometimes the run is done in third if the vehicle has a speed cut and cannot be taken right out.
So there is a difference in output between the gears. I'll put this down to load (ramp rate)... same way that full boost in first happens about the same time as the rev limiter. Load is important to turbo cars...
Theoretically, shouldn't the kW be the same, because it will register as more torque and less speed? and also, a lower gear with a higher ramp rate ('magically' matched, or course) should produce the same load on the engine, so the same amount of kW...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
