was after some opinions on screamer pipes. currently i have a hks style split turbulence dump on there at the moment, but i am going to higflow the turbo, so i was wondering would it be beneficial to have a screamer or just keeping the one i got?? i am not really that concerned with the legality of it either. just wanted to know if it will pick up a bit more power and whether it would sound good.
cheers
https://www.sau.com.au/forums/topic/123832-screamer-pipes/
cheers
Mate screamer pipe is the way to go
i got my wastegate pipe in the Atmosphere and it sounds like a jumbo jet is comming,As for power it depends how restrictive your exhaust is
what turbo and exhuast you running
https://www.sau.com.au/forums/topic/123832-screamer-pipes/#findComment-2286386
Key difference you are forgetting
You are using a External Gate.
The starter of this thread, using an internal gate
Its like comparing apples and oranges, they might be fruit, but nowhere near the same as each other
I would doubt it will pickup power. And i doubt it will "sound good"
https://www.sau.com.au/forums/topic/123832-screamer-pipes/#findComment-2286405
sorry my mistake
miss read
https://www.sau.com.au/forums/topic/123832-screamer-pipes/#findComment-2286414
ive seen the light with internal gated screamers......
i gained power by plumbing it back up....... it also helped me clear my EPA notice too.... split is the way to go .. no doubt about it
screamers are fun, i loved the WTF expression id get when u'd open it up..... but robbed me of a fair bit of power........wont go back to screamer unless i have an external gate .. and 2 3/4 pipe sticking off it
https://www.sau.com.au/forums/topic/123832-screamer-pipes/#findComment-2288038
split dump/front pipe - over 3" dump/front pipe????
split dump is the way to go. Causes less turbulance in exhaust gas flow when the exhausts from the gate re-enter and therefor improving flow/velocity. Most of the split dump pipes are calculated correctly with length etc to minimize turbulance and maximize flow and velocity, which is what you want.
https://www.sau.com.au/forums/topic/123832-screamer-pipes/#findComment-2293036
was yours a standard turbo? or was it one of the ones with the split section for the wastegate like the HKS ones?
https://www.sau.com.au/forums/topic/123832-screamer-pipes/#findComment-2293046
