for starters, the link above doesnt show any electric super chargers as we know them. ie they arnt the blower type. looks at the site.
secondly, to make 2psi the so called electric supercharger has to make the 2 psi pressure ON TOP of what the engine is sucking in.
the blower type superchragers are rubbish, the things shown in the above site are rubbish.
steve
Ohh fair enough just got the link working in mozilla, hadnt seen it earlier, assumed he was talking about the type i was above.
dunno anything about these kits but they look like they'd work almost as well as the turbonator...www.turbonator.com... buy 3..
Edited by r32 gts-turbo
.. just looked at the product mentioned, and not a "Supercharger" as we know it but more a brand name that represents Voltage stabilizer kit.
I dont how people can charge (no pun intended) $999 your for what is basically a few capacitors and larger guage earth wire.
f*cking tossers. You may as well go buy some cheap magnets and stick 'em up your arse.
Please keep any ghey external electric supercharged 2 PSI hoo-ha out of this thread!! :)
Due to the name 'Electronic Supercahrger' I was under the impression that this actively raised amp/volts or the like :D I have no clue about electrics if you have'nt guessed :)
It's obvious there is no viable reason for them to be asking the stupid amounts of $$$..
But could someone go into more detail how these are meant to work and what benifits can be had?
theres no way you can actively raise voltage/current.
best thing to do, is have a nice clean set of battery terminals, clean connectors on your alternator, and some nice thick wire bolted from various points around the the engine to the engine bay. Also have a fat wire running from the negative battery terminal to the clean spot on the engine and car body.
a good earth can solve some weird problems.
you can invest in a kit if you want name brand stuff, or you can go to dicksmith/marlow and get some thick black cable and make your own kit.
Steve
for ~600 you can run at 2psi... on a small engine.
Think about it - they run on 12V DC...
I did a fair bit or research on them - for my magna (when I had it). It it was $200 I might have considered it (and it still would probably have been a waste of money). If you really want, I could share it. Just don't expect me to be nice about it.
You have a turbo charged car. Why get 1/4 kw for the first 1000 rpm in return for blocking the air intake when the turbo spools? spend the money on something that improve your car
Noticed an ad in HPI #67 for an Australian company called Cre8tec. The product they were advertising was the 'Electronic Supercharger' Wich they claim can increase engine torque by up to 20%!! Umongst other things. Has anyone used this product? Is it probable that it could help with increasing turbo response?
Also have heard stories of slightly increased turbo response from installing Earthing kits. These are getting cheap now days.
Thoughts and experiences please :(
Due to fools spamming up this topic.. This is what the so called 'Elctronic Supercharger' looks like
-It has no fan
-It does not make boost
-It does not restrict the inlet passage
This is the $999 version :happy:
Forgive me for getting the wrong impression. Understandable (I think), but wrong nonetheless. It "supercharges" the electronics. Looks like an earthing kit with some sort of ballast(capacitor?).. Um.. an expensive earthing kit.
I don't see how this could have an effect on boost (unless your plugs are dead to begin with - and even then...)
So, sorry I was wrong, but I still say its a rip off. you could DIY it pretty easy - though I wouldn't really like to think about what a capacitor would do to voltages and power (electric - real and 'imaginary') when the spark plugs are firing. I guess it wont kill the car... and if you DIY, you can always unDIY...
**fool spamming up the topic, out
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
