  • Replies 47
I know it was stupid to tap the brakes but I wasn't really thinking and they were pissing me off.
I'm going to call the cops every time I see them and hopefully they will get them. I'm pretty sure if they get pulled over the cops will find drugs and be able to defect them as well.
For those of you in the area it happened on Englorie Park Dr in Glen Alpine.
The cop I spoke to said to not leave my details when I call otherwise I will have to do a statement every time and then when they do get caught they won't know it was me because the police will be taking them to court or whatever.
If they do somehow find out it was me and anything happens to my car, I feel very very sorry for them because it won't be hard to track them down and make their life not worth living. Hopefully this won't have to happen though.
So what's the difference between them tailgating you, and you brake-checking them? None really. They're both instances of aggressive driving.
I don't really understand why you are gonna be reporting them to the cops everytime you see them, based on one incident..but each to their own.
They didn't just tailgate me, they swerved at me as they went past. I was only reacting to them, I wouldn't do it normally but they were being a dickhead. I'm going to report them every time I see them because I have never had someone drive so badly and try to run me off the road. Although with the way they drive they will end up dead sooner or later.
I hate to plug the New Zelander's but sometimes I really wish NSW had a scheme like this:
http://www.police.govt.nz/service/road/roadwatch.html
It says:
"The Community Roadwatch programme has been designed for use by New Zealand Police to advise the owner of a motor vehicle about the unsafe or risky driving behaviour you have observed and reported where you do not wish the offender to be prosecuted. The Police will regard your report as confidential; in accordance with the provisions of the law as it relates to privacy and disclosure of information.
If you wish the incident to be investigated with a view to charges being laid in Court you must lodge a formal complaint with your nearest police station."
Driving a skyline for many years in syd, it's rare to not have a drive where you don't encounter an idiot.
best of luck!
What's the difference?
They tried to run her off the road. That is the difference. Ever been run off the road raz0r$sharP? Ever had someone swerve their car at your Skyline on purpose? Ever been scared for you life...
Sure we all react differently to situations, some ppl can brush things off, some can't. I tend to think I keep cool about most things, and am comforted in the fact that generally what goes around comes around...But posts like yours do nothing but push buttons. The wrong ones.
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
