hi
i got a canary on friday and they took digi photos of my BOV, AVCR and the Boost kit for the avcr in the engine bay!!! :D
i hope this isnt too bad, ive been told i might get a letter from the EPA soon. :laugh:
anyway i have coilovers and i have to raise the car 25mm, i was wondering if they are illegal?
i have Hks Hyper D's and im hoping i dont have to change them???
Any help with the situation??????
cheers
steve
https://www.sau.com.au/forums/topic/123849-coilovers/
From my experience coil over type suspension will pass road worthy standards in victoria. It must exceed the original spec suspension in load bearing and all clearances must be kept in line with Vic Roads Modification guide and roadworthiness standards.
More information here
http://www.vicroads.vic.gov.au/vrpdf/rdsafe/VSI%208.pdf
http://www.vicroads.vic.gov.au/vrpdf/rdsafe/VSI%2026.pdf
https://www.sau.com.au/forums/topic/123849-coilovers/#findComment-2287016
Thanks for this - was just cruisin the forum and came across the info.
Who knew that Governments put out good guideline documents :(
https://www.sau.com.au/forums/topic/123849-coilovers/#findComment-2290480
Thanks PJ. Great help!!!
im gona print this out & leave it in the car so as long as im right i can stick it up the cops ass!!!!
cheers
steve
Not until you get an "approval certificate". The polive have every right to defect you until then.
I'll assume "approval cert" is another word for an Engineers Report which can attained from any Engineer thats approved.
Suspension Modifications are NOT legal until approved
https://www.sau.com.au/forums/topic/123849-coilovers/#findComment-2291761
Sort of right.
If you modify the mounting points of your suspension - ie - structural modification you require an engineers report that must deatil the how the modification has been done and how it meets or exceeds the manufacturers specs. The modification must also be safe and in accordance with ADR's and state/ territory roadworthniess standards.
If you use aftermarket suspension items that mount to the factory points - such as lowered springs, shortened struts, coliovers etc these only need to meet roadworthiness standards such as bump stop clearance, vehicle ground clearance and so on.
Each aftermarket suspension item to be sold in Australia must meet ADR approval for its design and structure in it's own right. That is why you do not require an engineers certificate for lowering a vehicle or using coilovers.
However, this will not stop Police from defecting you because they do not know the rules of what you can and cant have. To issue a defect notice in Victoria they (police) only have to have a suspicion that the vehicle is not modified in accordance with guidelines or is not to road worthy standards. It is then up to the owner to have the defect cleared.
In my experience both professional and personal I have not problem with passing raod worthy tests in victoria with Coil over type suspension.
https://www.sau.com.au/forums/topic/123849-coilovers/#findComment-2292243
I would very much doubt people are purchasing coil-overs on Aust shores.
The odd few, yeah. The majority however are not
1) Price
2) Car probably comes with them from Japan
My car was unable to pass engineers long ago because the suspension was TOO hard.
The engineer wasnt satified as part of compliance that there was enough travel.
And rightly so in my view. You couldnt move it they were that hard so a softer set was used and passed without issue
Obviously there is more to it regarding suspension travel among other things... but im no engineer
And i totally agree about defecting. Its based on suspicion, not fact.
I've long had that gripe, and it will forever be that way i think
https://www.sau.com.au/forums/topic/123849-coilovers/#findComment-2292323
I had a cop mention this to me ages ago about coilovers... asked him to explain why or quote the VSR that refers to coilovers being illegal and he had no response hehe
I am from Perth. Do you guys get knocked back for "Springs to hard"? we have been getting it a bit over here lately however there is nothing in writing as to what is too hard, or too soft. so what do you do?
https://www.sau.com.au/forums/topic/123849-coilovers/#findComment-2296469
Seriously, if they say coil overs are illgeal, is it time we perhaps explain the difference between cars with strut and wishbone suspension? Skylines have coil overs as standard. Im not one to chat back, but if they are confused by this, then perhaps they are confused about the law they are trying to intepret/administer
https://www.sau.com.au/forums/topic/123849-coilovers/#findComment-2296565
I think that the assumption that is being made by the police is that coilovers = adjustable (since most of them are) Iirc, you can replace suspension components as long as they are not adjustable. Where this leaves things like "gas rider" height adjustable units I'm not sure.
https://www.sau.com.au/forums/topic/123849-coilovers/#findComment-2296668
hi
i hope this isnt too bad, ive been told i might get a letter from the EPA soon. :)
cheers
steve
Hey Steve,
You just worried about the coil-overs.
Wait until they tell you all the other items have to go .
https://www.sau.com.au/forums/topic/123849-coilovers/#findComment-2299570
I'm with Roy. Coilover means the coil is over the shock and thus this is standard for a Skyline. Adjustable heights don't make them a coilover.
Just because they are adjustable doesn't mean you have actually broken the law. If you set them too low then 1. wear the fine, and 2. your car WILL handle like crap.
As lomg as the item meets travel and quality of manufacture requirements it is legal, else the entire non-genuine spare parts business is illegal.
https://www.sau.com.au/forums/topic/123849-coilovers/#findComment-2299757
Sort of right.
This post is 100% right
That is all
P.S. why are u even worried about this, cops only eva check for ride height.
https://www.sau.com.au/forums/topic/123849-coilovers/#findComment-2305104
  • 3 weeks later...
I Dont know much about it really but wouldnt this be part of the Compliance process and ADR with cars that come with it from Japan... Mine came with Hks coilover Adjustables from Japan and has since passed Complience and 2 roadworthies issueless, one in mebourne and one in country Victoria...
https://www.sau.com.au/forums/topic/123849-coilovers/#findComment-2346273
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
