Hi, has anyone had any BUZZING in speakers, run from an amp mounted on the strut brace bracket in the boot of an R33 GTR. I have been told this is common for R33'S and worse for GTR'S ,as the battery and computers are in the boot
and the GTR fuel pump is bigger.
No buzzing when speakers are run through the factory wires.
The fix,i'm told,is to mount the amp away from the boot area,ie under the rear seats.
BUT i cant be bothered to do this...I'v put in a noise supressor kit on the battery and no good.
The amp is a fairly cheap one,can this be the cause of noise?
Will a better quality/expensive amp have better noise supression?
HELP ME!!
:D
Edited by horn
https://www.sau.com.au/forums/topic/123853-buzzing-in-speakers/
There is alternator whine, which is a high-pitch whine with the revs of the car.
The buzzing though, could be something else. I suspect it's going to be the typical power interference thing though.
Try turning your gains down if you can't seperate the cables any more than you can.
I have a similar problem, but I haven't finished moving the amp around and deciding what i'm going to do.
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
    • The ones in brackets are the first stages of tightening. I usually aim for the middle of the range. They give a range because it's actually not that critical to hit exactly the right bolt tension. Enough is enough, and too much is too much, and the range given is inside that range. Half of the bolts in the suspension are problematic for putting a torque wrench on anyway, so just get done up to mechanic tight  and spanner checked a week later.
