motec are looking for a system admin, sounds pretty good actually.
almost tempting. its on seek for those interested. at their research centre in croydon.
dyno on site among many other super cool tools i would imagine.
there would be some sweet equipment there, im sure their IT stuff would be top notch
https://www.sau.com.au/forums/topic/123855-sysadmin-job-motec/
  • Replies 73
I had an interview for a position as a Software Engineer there on Wednesday.... we'll see how it goes :D
They gave me a tour of the place too :D
-Patrick
*shakes fist* no no no :dry:
Mine was at 10, when was yours?
damn..... that job would be perfect for me! Pity i still have 6 months left of uni :huh:
Fairly simple setup by the sounds of things. (yeah, $50-60k sounds right)
just do the last few subjects part time if you get the job. work experience is more important than uni experience (yes i went to uni full time, wish i didn't)
    • There's no way they left the factory like that. In R chassis there is nothing stopping the steering wheel being put on one spline out from straight, and then adjusting the steering arms to "correct" it (sort of). As well as the indicator cancelling there would also be an issue with how tight you can turn in one direction to the other. The other (less likely) possibility is that the "clock spring" (the circular electronic part that allows the wheel to turn while still having an electrical connection for horn and any other buttons like cruise) might not be in place correctly. I don't have any pics of the R33 (or Stagea) setup but there would be a circular locating tab which sits in the steering column to have it straight...if that is not seated properly then the indicators may not cancel at the right point (and, you might also get a HICAS error since it would think you are driving in circles)
    • It will mostly be bad scoring on the bores, which you can almost certainly fix by machining for oversize pistons. I have to say, I am super surprised that any standard turbos made it 35 years down the track before exploding!
    • Thanks for the info mate was thinking 255/35 rears and 235/40 fronts
    • What's the difference? I would have said that between the front and rear axle lines, there's no noticeable diff between a GTR and an NA 2-door.
    • It will be salvageable. It really doesn't matter what is damaged. Opening up a 30+ year old motor for a rebuild immediately means a complete rebuild of the head anyway. Damaged valves just means an opportunity to put in some nice new ones. And in the modern day, why would you not throw at least a nice set of pistons at something. And if you're doing that, why not rods, and ARP fasteners, and so on.
