  • Replies 73
just do the last few subjects part time if you get the job. work experience is more important than uni experience (yes i went to uni full time, wish i didn't)
only 6 months to go! may as well get the degree over and done with! (comp sci, monash clayton)
i've been working casual as a network admin for a couple of small offices, very similar to the sort of stuff they mentioned in the add, so sadly they aren't advertising at the end of this year, otherwise i'd be applying!
I would give them until Friday and perhaps make a call in the afternoon unless they gave you any details during the interview about quantities of interviewees, time spans to interview them etc. I would always add a week onto the end.
Good luck anyway and hopefully roll on the group buy :D
ive always thought if a company is hiring someone to do a range of tasks instead of a few ppl that specialize in various things there usualy kinda cheap...
im betting around the $50k mark :)
With 3 to 4 yrs experience & the wide range skills they are asking for, I would expect $70-$80k+ IMO.
Emailed them for a $ figure anway.
Thats easily gonna top 50k.
Im with Dave. well into the 70k region. If not more
I mean, the stuff this role incorporates, my work pays people closer to 80k no problem.
Im on the chicken feed @ around 50k and i dont do anywhere near that sorta stuff :)
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
