  • Replies 73
just do the last few subjects part time if you get the job. work experience is more important than uni experience (yes i went to uni full time, wish i didn't)
only 6 months to go! may as well get the degree over and done with! (comp sci, monash clayton)
i've been working casual as a network admin for a couple of small offices, very similar to the sort of stuff they mentioned in the add, so sadly they aren't advertising at the end of this year, otherwise i'd be applying!
I would give them until Friday and perhaps make a call in the afternoon unless they gave you any details during the interview about quantities of interviewees, time spans to interview them etc. I would always add a week onto the end.
Good luck anyway and hopefully roll on the group buy :D
ive always thought if a company is hiring someone to do a range of tasks instead of a few ppl that specialize in various things there usualy kinda cheap...
im betting around the $50k mark :)
With 3 to 4 yrs experience & the wide range skills they are asking for, I would expect $70-$80k+ IMO.
Emailed them for a $ figure anway.
Thats easily gonna top 50k.
Im with Dave. well into the 70k region. If not more
I mean, the stuff this role incorporates, my work pays people closer to 80k no problem.
Im on the chicken feed @ around 50k and i dont do anywhere near that sorta stuff :)
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
