Hey guys,just got my internet connection,nice to c u all again
Im just not sure of what turbo to get.My current snail is already extracting 245hp on the wheels but we all want the power.I want like a drivable,wider power band turbo.
Im looking into a t3/t4,but i want to know other options.350hp-400hp would be nice,what do you think?
Outlaw Racing
13.6
(******** waiting for my panels)
https://www.sau.com.au/forums/topic/12386-turbo-choice/
Originally posted by GTS-t VSPEC
A t3/t4 turbo is not going to get much more than 330rwhp, but they do bolt on so there is no change of manifold. I personally would go for either the GT28 or GT30 series, but I'm after big power:D
See'ya:burnout:
Adam has a T3/T4
u reckon it wouldnt get a rb25 past 330
whatsisname is pullin 250kw@13psi
Shuto u dont have to go that big to get 400hp@engine
https://www.sau.com.au/forums/topic/12386-turbo-choice/#findComment-225324
Just to expand on the topic.
What is the best turbo to use, that has the same or better characteristics as the standard (low rpm boost, quick spool up, etc.) and makes bigger power and bigger torque? Hope you understand what i am trying to ask.
Or is it better just to hi-flow the standard turbo with a sierra-sierra combination on the compressor and exhaust sides?
https://www.sau.com.au/forums/topic/12386-turbo-choice/#findComment-225331
We have a nice little bolt on Hybrid built up that flows 430hp @ 1 bar and is a straight fit internal gate job. I've got one on the Stagea and it spools up just as quick as the stocker. The good thing is its quite tractable on 7psi so you dont need to upgrade everything else at the same time. A point of reference the stock AFM maxxes out on a cold night on 7psi with this terb...
Jash
https://www.sau.com.au/forums/topic/12386-turbo-choice/#findComment-225474
Thanks REV210!
How much rwkw (approx.) would this give me, at what psi?
How much torque can i expect (prefably as a % over stock turbo, eg: 45% greater torque)?
when this turbo upgrade is done, the car will have the following mods:
- Wolf3d V4 plug-in
- fmic
- cold-air intake (sealed box with 4" drain pipe from hole in front bar)
- Adjustable boost
- heavy duty ceramic/brass button clutch
- 3" exhaust system (from turbo, with hi-flow cat and straight through muffler.
- sard 550cc injectors
- Bosh fuel pump
- Bosh fuel regulator
- Ceramic coated: ic pipes, turbo housings, ex. manifold, dump/front pipe, etc)
Would i need any other mods?
https://www.sau.com.au/forums/topic/12386-turbo-choice/#findComment-225475
Jash (GTAAH) Thanks!
How mush ($) am i looking at?
Is this a BB turbo?
Will it fit on the stock manifold?
Is it a hi-flowed stock turbo?
PLEASE refer to post addressed to REV210, and if possible kindly answer the questions listed, taking into consideration the mods already, or about to be fitted, on the car.
THANKS AGAIN
SHUTO-BOY
Sorry if i taken over your thread, but i think this type of information could also help you.
BTW with the first six mods listed (the rest are yet to be completed when i get the turbo) i am making 210rwkw with alot more low to mid range torque/drivadilty thanks to the wolf3d.
I would seriously consider any type on engine management b4 the turbo upgrade, just to get the mixtures right. I have already seen 2 R33 with blown engines, due to bigger turbo's and poor tunning. Just my 2c worth.
https://www.sau.com.au/forums/topic/12386-turbo-choice/#findComment-225517
The complete replacement turb is a BB, new. Its custom made to our specs by Garrett and is a nice little unit. Needs custom oil and water lines but everything else bolts up.
We are looking into getting turbo's remanufactured but its proving to be quite an operation, apparently they can be done with BB Cores now, but they are 2200 ish which makes it not really worthwhile.
Jash
https://www.sau.com.au/forums/topic/12386-turbo-choice/#findComment-225825
Jash if you can sell them for $2k even 2.2 like u said that maybe ok because the key here is they bolt up no intake and dump alterations which makes the whole operation so much cheaper :D
BTW id like to know wheel sizes of the BB Turb when u answer Al :D
Rev210 the 2530 will spool fast cause its a toy turbo. 2540 isnt far behind!
https://www.sau.com.au/forums/topic/12386-turbo-choice/#findComment-225950
