4) intercooler has the inlet on the top half of the core, but the outlet on the bottom half of the core, and i'm not sure this is the best for flow...
There is a good reason to be doing this. It helps ensure that all the runners inside the intercooler get equal airflow. So by makign sure air passes through the intercooler evenly you are maximising its effeciency. A good example is an EVO intercooler. Look at how many big HP EVO cars run the std cooler. Hell you see EVOs running sub 58s laps at Tsukuba so that general desing has to have merits (Ditto cooler on LeMans cars etc)
even easier .. T it into your BOV pressure feed .. done
Your BOV normally gets its signal from the inlet manifold. Generally it is recommended that you get your boost signal from the intercooler pipes or pre throttle body. Why thats the case i dont know, but most instruction manuals state thats how to do it. And also i suspect a pressure signal off a BOV would pulsate or be unstable pending what the BOV and the throttle are doing?!?!?
SO just get a threaded barb and carefully drill a hole and tap a hole. Hell if the pipe is alloy and you use a stainless barb etc you wont even need to tap it, just use a neat bit of thread tape. (Saves welding one)
this is true roy, but a pressure feed is a pressure feed..
running a boost crontrol from the thing where boost is measured makes more sense to me.
just say in a higher boost situation where the intercooler is not working efficiantly then you will see a drop in pressure at the inlet plenum and possible rise turbo side of the cooler.. which would cause the wastegate to open further and reduce boost pressure at the plenum .. hence why alot of cars drop boost down the rev range.
thats my reasoning for using a plenum based feed for the boost control..
Edited by Craved
Yeh i suppose it depends on your form of boost control? If its electronic you can still run the MAP sensor straight off your inlet manifold. But the line you use to cheat the wastegate can be the outlet of the turbo or anywhere before the throttle body
If its a mechanical means of boost control then fair enough. But again running a t-piece from the BOV line may mean you end up with 450mm or so of tube, and generally the shorter the hose the more accurate the boost control (I assume thats why they run it off the compressor cover as std on RB20s)
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
