i would try skylinesdownunder i got a pair of mint ones a few months ago from NZ for $80 but if all else fails Grandauto wreckers at Lonsdale have a pair for $400 but the guy there said he would do them for $350 when i was in there on the weekend and when i told him i already ha a pair i got for $80 he wasn't to interested in helping me anymore lol but $400 i a rip off but i guess thats up to you
https://www.sau.com.au/forums/topic/123883-r30-stovetops/#findComment-2292567
:kiss: yeah the damn pin prick from grand auto quoted me $450 on the weekend so i tossed that idea lol then came here hoping someone wanted to hook me up cheaper lol i'd rather spend money on better things then $450 tail lights lol ohwell i'll keep searching cheers anyway mate
paul.
https://www.sau.com.au/forums/topic/123883-r30-stovetops/#findComment-2294450
  • 3 weeks later...
    • So, cams are not getting installed......yet  Had a good chat with MX5 Mania about intakes, they recommend not to get ITB's, they recommend a plenum style for the NC So, one of these puppies is being ordered, with a larger TB to suit, when it arrives from the US the car will go in for the cams and intake I'm also getting a fancy rear box bit for the air filter box which will suit the new TB size
    • Clamp meter is pointless. Unless you're trying to keep average current under a set value for some weird reason (maybe you undersized your wiring?), then you'll get no useful info. What you're really trying to target is the flow of fuel coming back to the tank. You want some, but not a lot. You also want to make sure fuel pressure remains stable.   So, fuel pressure gauge, and fuel flow gauge. Set it up from that.
    • Aside from the fact it is likely fuel related if it is black, the symptoms otherwise sound like worn valve stem seals. Oil gets past the worn seals when the engine is off and burns when the engine starts. If it happens on deceleration while driving (puffs of white smoke) that is another valve stem seal symptom because oil gets sucked form the head into the combustion chamber under vacuum with the throttle closed. They can be replaced in the car if you have some way to keep the valves closed while working (eg compressed air into cylinders) but is much easier with head off.
    • Alright, fair enough. Expected as much. Possibly, yes. However the kit is apparently not including every single hose and it is out of stock too.
    • I sourced my silicone hose kits from Just Japanese. Their current link is what I posted above but supplier might have changed over the decades.
