  • Replies 58
Hi guys, we have found no difference in the flow of the R34 RB25DET injectors to the R33 RB25DET injectors, they both appear to be 370 cc's. We get around 250 rwkw (400 bhp) on the standard injectors in both before they run out of flow, that's using a GTR fuel pump though.
We use Series V RX7 Turbo injectors in RB20DET's as they are 550 cc's and top feed, high impedance so they work with the standard ECU (or Power FC) without any hassles.
I know that the R33 RB25DET's injectors are side feed, high impedance but I have not yet had to pull a set out of an R34 RB25DET, so can't help there.
INASNT,
given that they flow 370cc/min each at 100% duty cycle, i calculate that they should be good for a total maximum of approx. 440hp or 330kw (flywheel) which would give you your 250rwkw.
Although, of course, i'm not too sure if the OE fuel pump can keep up with the fuel flow needed for this power, but yes, a hi-rise fuel press. reg. would definitely help.
The fuel pump pumps less volume of fuel the more the pressure is raised. So to squeeze every last drop from the std injectors then you need a very big pump to be sure of decent fuel supply. A bosch 044 would be the go and then you can get quite alot out of the std injectors.
Hi INASNT. you asked "how did u manage to get 250rwkw out of the stock r33 injectors?"
We have done this more than 5 times in R33's and twice in R34's, so it is certainly not a one-off, lucky break. We generally use R33 GTR fuel pumps and Tomei fuel pressure regulators. The exceptions were that one of the R34's had a Tomei fuel pump and no adjustable fuel pressure regulator and one of the R33's had a Bosch 044.
All of them had Power FC's and were tuned for air fuel ratios between 11.5 and 12 to 1. They had a variety of other mods including hi flowed, HKS & Garrett upgrade turbos, camshaft pulleys, camshafts, exhaust manifolds, exhausts (generally with split pulse dump pipes) etc.
When we put an R33 standard fuel injector to the flow test (after ultrasonic bath cleaning) we find that they have flow rates ranging from 380 to 395 cc's. The 370 cc rating has always seemed to be a bit conservative. When we over pressure them (using a higher flow and pressure pump and adjustable fuel pressure regulator) we find an extra 10% flow is typical and sustainable ie; 420 cc's is very common.
The real world experience is backed up by the mathematics, if you take say 6,500 rpm, at 2,476 cc's, over 6 cylinders, with an a/f ratio of 12 to 1 and boost of 1.3 bar, you end up with 313 cc's of fuel being required every minute. If you allow 80% duty cycle ie; leaving 20% for acceleration, start and cold run enrichment, that = 391 cc's which is within the scope of a standard 370 cc injector to provide.
Hope that helps.
PS; that's why we never do the "GTR injector in GTST" mod, the extra capacity with 440 cc's is simply not worth the effort (or cost) when we can easily get 420 cc's out of the standard injectors.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
