  • Replies 58
Hi guys, we have found no difference in the flow of the R34 RB25DET injectors to the R33 RB25DET injectors, they both appear to be 370 cc's. We get around 250 rwkw (400 bhp) on the standard injectors in both before they run out of flow, that's using a GTR fuel pump though.
We use Series V RX7 Turbo injectors in RB20DET's as they are 550 cc's and top feed, high impedance so they work with the standard ECU (or Power FC) without any hassles.
I know that the R33 RB25DET's injectors are side feed, high impedance but I have not yet had to pull a set out of an R34 RB25DET, so can't help there.
INASNT,
given that they flow 370cc/min each at 100% duty cycle, i calculate that they should be good for a total maximum of approx. 440hp or 330kw (flywheel) which would give you your 250rwkw.
Although, of course, i'm not too sure if the OE fuel pump can keep up with the fuel flow needed for this power, but yes, a hi-rise fuel press. reg. would definitely help.
The fuel pump pumps less volume of fuel the more the pressure is raised. So to squeeze every last drop from the std injectors then you need a very big pump to be sure of decent fuel supply. A bosch 044 would be the go and then you can get quite alot out of the std injectors.
Hi INASNT. you asked "how did u manage to get 250rwkw out of the stock r33 injectors?"
We have done this more than 5 times in R33's and twice in R34's, so it is certainly not a one-off, lucky break. We generally use R33 GTR fuel pumps and Tomei fuel pressure regulators. The exceptions were that one of the R34's had a Tomei fuel pump and no adjustable fuel pressure regulator and one of the R33's had a Bosch 044.
All of them had Power FC's and were tuned for air fuel ratios between 11.5 and 12 to 1. They had a variety of other mods including hi flowed, HKS & Garrett upgrade turbos, camshaft pulleys, camshafts, exhaust manifolds, exhausts (generally with split pulse dump pipes) etc.
When we put an R33 standard fuel injector to the flow test (after ultrasonic bath cleaning) we find that they have flow rates ranging from 380 to 395 cc's. The 370 cc rating has always seemed to be a bit conservative. When we over pressure them (using a higher flow and pressure pump and adjustable fuel pressure regulator) we find an extra 10% flow is typical and sustainable ie; 420 cc's is very common.
The real world experience is backed up by the mathematics, if you take say 6,500 rpm, at 2,476 cc's, over 6 cylinders, with an a/f ratio of 12 to 1 and boost of 1.3 bar, you end up with 313 cc's of fuel being required every minute. If you allow 80% duty cycle ie; leaving 20% for acceleration, start and cold run enrichment, that = 391 cc's which is within the scope of a standard 370 cc injector to provide.
Hope that helps.
PS; that's why we never do the "GTR injector in GTST" mod, the extra capacity with 440 cc's is simply not worth the effort (or cost) when we can easily get 420 cc's out of the standard injectors.
    • When: 5 & 6 September 2025 Where: Sydney Motorsports Park Join SAU NSW at World Time Attack Challenge 2025 at Sydney Motorsport Park. Plans will be finalized closer to the day, but make sure you lock in the days in your calendar now!
    • When: 9th August 2025 Where: Meet details to follow, budget half a day for just the museum part of the cruise, or a full day if you want to come up the range with us after! Join us for a cruise to Albion Park to visit the Historical Aircraft Restoration Society Aviation Museum for their August open Tarmac weekend. Walk around the hangers and see these amazing classic aircraft up close. After a two hour break to look around you are welcome to join us in heading up Macquarie Pass to the Robertson Pie Shop for a bite to eat. After a bite we will head back down Jamberoo Mountain Road before returning to Sydney. Full details to follow, for now lock in the dates into your calendar!
    • This is a school night cruise! Join us for a mid week night cruise up the Old Pac. We will stop at McDonald’s in Gosford for a quick break then come back the same way. Date: Thursday, 26th June 2025 Meet Location: Cowan Truck Stop (Pacific Motorway - Refer to Map) Meet Time: 7:30pm for a 8:00pm departure Destination: Gosford McDonald's (65 Pacific Highway, Gosford West) Map: https://maps.app.goo.gl/wi7jcuGxpJsoKtJB8 This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave.
    • Join us for an epic Saturday at JDM Festival! We'll kick things off with a feed at Big Fat Greek Campbelltown to fuel up with some delicious eats and good vibes. After the feast, we’ll cruise over to Sydney Motorsport Park for the main event: JDM Festival! Please note: space is limited and depends on the number of SAU NSW members who commit to attending. To help us plan accordingly, we appreciate your timely registration. Date: Saturday, 14th June 2025 Meet Location: Big Fat Greek, 2 Rennie Rd, Campbelltown NSW 2560 Meet Time: 2:30pm for a 5:00pm departure Destination: Sydney Motorsport Park, Ferrers Rd, Eastern Creek NSW 2766 Important Information: Spots are limited and will be allocated on a first-come, first-served basis, with priority given to current financial members. REGISTER YOUR INTEREST HERE This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • You'd want to cap off the re-entry back into the dump too. Just something flat that can be held on by the Vband.
