Wide Bay Sprints At Maryborough
giant getting air
Brenken's Falken GTR production car (of Bathurst 12hr fame)
couple of 33s I don't know
Looks like a great event. If I had known giant and brenken were running I would have gone up for a look.
not sure Dale. I wasn't there and didn't get regs or anything for the event. Hopefully Giant or Brenken will see the thread. I have a mate who ran there too, so i might give him a call and find out how he went.
I really wish I went now, I think Brenken's GTR came 3rd overall in the event?
The white skyline without a front bar came first in it's class, not sure which class that was exactly...I really should have gone.
i had some mates go up to it. apparently those skylines were 'cranky'. one of the 'lines got booted out cause the guy did a good time on saturday, then on sunday decided to drift the whole course.
Not surprised, most sprint organisers don't like it when people drift... to much chance of wrecking stuff !
Alot of the guys at the Townsville one were starting to do it , and we just got a big chat too last meeting. As ours is run on the Townsville Kart Track... the kart track owners were getting annoyed with it.
That black GTR was at the first local hillclimb this year .... was quite a weapon for sure..... and he now holds the track record by 3 seconds !
Gary
Although there website's main index.htm page is damaged/missing , i found my way in and saw this notice ...
Quote:-
The Track is approximately 960 meters long with two 45 degree right hand turns, several chicanes and then into a right hand hairpin turn leading onto the main straight. This will be a Race Track and not a Drag Strip !! No Drifting allowed !!!! "
End Quote
;) See no drifting comment
Hey Gary,
Thought that might have been the gtr that simon said came up there and blitzed it. It was on tv, winning the NSW dutton rally.
Yeah the drifting comment looked a big amateur though on that webpage.
I bet jaimen in our old T18 was one of those drifters too, lol.
Tim.
Hi Tim, yeah well it's understandable they don't want it . Crowds love it of course..
Yes it certainly was a fast car.
One of many i think ! Also this was the event just after the gtr had the off on the cool down lap, and took a gouge out of the bitumen... so they were really cranky.
Gary
i don't know if any of those guys have ever been to a drag stip, but i haven't seen a drag strip yet that has a corner after 200m for you to drift. i'm sure people drift the corner at the end, but that isn't part of the drag strip, thats just a return road which i would class as the pits.
 Share
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
