Hey,
When im taking off quick and putting my foot down the back end starts jumping all over the place. its hard to get it on the ground and to make it stop bouncing. I have to keep taking my foot off the pedal and putting it down again. Does anyone know why the car isnt keeping on the ground. Could it be suspension or diff or something??
Thanks!
https://www.sau.com.au/forums/topic/123918-back-end-is-jumping-off-the-ground/
If the cars "jumping" rather than simply breaking traction, id say its most likely your shocks/springs in the rear. Either the shocks are on their way out, or the spring rates are wrong. Perhaps a suspension shock could shed more light on it.
Shocks will do it, so will over inflated tyres
Hey,
Thanks!
Sounds like axle tramp to me. Time for new shocks and check the subframe bushes.
:D cheers :rofl:
What your describing sounds like something more commonly known as axel tramp. It is pretty common in Skylines and probably many other models. A couple of ways to fix / improve the problem are:
1) subframe allignment bushes - these lock the rear subframe in position rather than having it able to move on its mounts.
2) good shocks / springs - another part of the problem is that the shocks / springs are not able to control the rapid oscillation of the rear end - a good combination of shocks ande springs will help.
3) As above make sure tyres are at correct pressure.
I've done all those three thinks and I don't have any problems at all lighting up the wheels withput them bouncing around.
Cheers.
Edited by JCMarshall_Law
What about in the wet? I have new shocks and subfame bushes!
When you have semi wet road, dry patches, you can get tyre sidewall flex and release due to the changing traction. Raising the tyre pressures usually stops that.
:D cheers :rofl:
:laugh: cheers :laugh:
Hey gary,
i am running a 225/40/18, the road was not patchy at all as it was raining, and im running the 32psi you recommend for the street.
I must admit that half the time its ok, just some of the time it tramps a fair bit.
I was trying a few different things , ie slipping or dumping the clutch at different revs, changin to second at different revs and throttle % and i could sort or drive around it but i was a little suprised because it is so perfect in the dry :laugh:
Thanks SK
Edit: SK you were right, tyre pressures were at 26-27spi, Whoops :cool:
Edited by 26GTS
    • Aren't these run off of high voltage in OEM applications? Like 200+V. Or at least 48V in mild hybrids. At ~18,000 BTU ballpark nominal capacity the power draw is at what, 2.2 kW? ~185A is a pretty crazy amount of amps. At 200V it's only 11A. The 70A nominal kits with up to 100A peak draw I see for stuff like classic Porsches have pretty substantial compromises like shutting off at idle and not actually managing to keep the interior cool in hot conditions because they can only output like 6000 BTU. IMO if I had to pick what high amp draw component to retrofit to these cars I would start with the engine fan, not the AC compressor. You need an ~850-1000W brushless fan, something like this: I would love to see the data but I would bet that whatever you save by running the AC compressor in a more efficient regime with an electric motor you're probably losing to conversion losses anyways. It's not really like a clutch fan where you're losing power all the time even when it's nominally disengaged and it gets worse as it engages because the envelope tracking isn't that precise.
    • I am a volunteer marshal at the Grand Prix. As such, I get a "friend / family" ticket. It is a general admission ticket, valid for all 4 days. Anyone interested in my spare pass, please DM me. Ticket is "free, gratis and no expense".
    • agreed, the price vs gains it’s there.   unless you go china supercharger. Temu racing anyone?😂https://www.facebook.com/share/15nkfpsg7Z/?mibextid=wwXIfr that was one of the ones that popped up on my feed 😂
    • Bit of a long shot but if anyone has 4 of these laying around in new or near new condition. I will happily buy them off you.     https://skylinespares.com.au/product/stabilizer-door-glass-inner-new-8032404u03/?srsltid=AfmBOop6L5EgUFaHPHiVXoAhv5k8aJYwc77nGmoApp-hY03OiOsNVaOv Thanks
    • I'm wondering is the Toyota and Mazda "collaboration" could see that new Toyota ???G20 ??? turbo engine that they have been showing off recently into a future MX5, apparently it's good for 400hp out of the box That could easily, possibly, be much better than the last collaboration between Toyota and Subaru with the boxer engine in the twins
