After looking for parts for my R33, i found that a fair few things are interchangeable with other makes and models. This morning for instance i rang burson, super cheap auto and repco and when asking for copper spark plugs to suit an r33, all stated they had nothing available, only iridium ones and they ranged from $108 to $150. When i found that the VL Turbo used the same thread i purchased them and they worked a charm for a total of $24.95 for 6
Spark Plug Part No for RB25DET
Recommended Plug: PFR5G-11
Iridium Option: BKR5EIX-11
INTERCHANGEABLE PART NUMBER (HOLDEN VL),
Copper: NGK BCPR6ES
The Water Pump can also be used from a VL, i think of the top of my head with just the relocation of 1-2 bolts. If you know anymore please add them
i FOUND THE BELOW ON OTHER SITES, CAN ANYONE CONFIRM ANY OF THE BELOW :
Rb25det series 1
Alternator rebuild -Power regulator.
Mitsubishi #IM 830-14.4volts (http://www.transpo.de/cgi-win/product.exe?IM830)
need to replace your clutch pivot ball you can use the 3rd Generation Nissan Maxima OEM Nissan P/N 30537-03E00
13070-42L00 rb series timing belt tensioner. Same part number as VG30E (84-89 300zx)
1991-1994 Z32 speed sensor WILL work with an RB25DET transmission
KA24DE Slave Cylinder Fits the RB25DET.
CLUTCH FOR RB20 AND 25 IS 300ZX N/A
o2 sensor that works from a 1984 200sx with the ca18et engine.
RB25 Series 2 MAF is the same as a 97 Maxima.
Most of the RB20DET Valvetrain is
Z32 300ZX parts
I know for sure the Valve springs, retainers, spring seats and keepers are the same
RB25DET Cam Seals are the same as the Z32 crank seal and the CA18 cam and crank seal.
Edited by mr_crust
https://www.sau.com.au/forums/topic/123932-interchangeable-parts/
VL water pumps are definitely the same as rb20det water pumps. i used one when i did mine, bolted straight on.
my mate from ultratune said they dont fit rb25s though... which i thought was a little odd, but i dont know.
those copper plugs fit rb20 too
Z32 300ZX parts
The springs are interchangable but not the 'same'. RB20det's are softer.
BKR7E and BCPR6E plugs are recommended int he RB25, RB20 and RB26.
Water pumps are interchangable, oil pumps are interchangable.
Cam belts are interchangable
rb20 de/det & rb25 de/det (series 1), rb26dett (r32) coil packs are the same
R32 and R33 series 1 AFM's are the same.
VL/R31 afm plug fits Z32 afm
rb20/rb25/rb26 timing belt same.
r32 (type m) / r33 gts-t rear brakes same
r32 / r33 gts-t exhaust manifolds same
r32 / r33 gts-t BOV's same
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
    • I feel like this is due an update
