Ive recently purchased a HKS Twin PLate. All ive evcer owned are standard clutches so im not quite sure.
when in nuetral u can hardly hear but its there but when yew push in the clutch and in reverse theres a really loud weirdass sound is this normal???
ive heard twin plates are generally noisy....
oh and also... is 0.9 bar ok for stock internals...
i have AM Cams, and valve springs though...
should i be worried about the clutch???????????
https://www.sau.com.au/forums/topic/12398-noisy-hks-clutch/
Nah my twin plate did the same thing in my 180SX. What happens is when you out your foot on the clutch the plates move apart (weight is off them) and they rattle a bit.. It takes a bit to get used to, as i had asked the same questions when i fitted mine. Thought it was boken or something..
https://www.sau.com.au/forums/topic/12398-noisy-hks-clutch/#findComment-226168
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
