I want to install a oil temp gauge in my R32.
Is there somewhere on the engine i can mount the sensor for a mechanical/electrical gauge?
I was thinkin of using an oil filter sandwich plate, but they look to bling to be any decent quality/good.
Any ideas of where to install the sensor?
Cheers
Ryan
https://www.sau.com.au/forums/topic/124024-install-oil-temp-gauge/
An easier way to measure it is via a oil filter sandwich adaptor, much like this one.
Agreed its the oil before it goes into the motor but unlike a radiator, oil doesn't cool much in the sump before it goes back into the motor.
Yeh that wat i was talkin about that sandwich plate. I dunno about it, looks like it wont give a proper seal and might not last.
Oil cooler is a bit of an extreme as i dont thrash it much :happy:
The other option i was thinkin is makin a T-peice where the sump plug goes and screw it in there. The only thing is swirling of the oil might miss the sensor.
Is there any where in the engine block i can put the sensor (ie unused bolt screwd in the engine)
most oil temp sensors have a large probe.
Greddy make a sump plug replacement that you can screw your sensor into..
if the swirling of the oil misses a sensor there, then your oil pickup wont be getting oil either ..
Good point Craved i wasnt thinkin
Did u have a link or somethin for the greddy plug?
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
