I want to install a oil temp gauge in my R32.
Is there somewhere on the engine i can mount the sensor for a mechanical/electrical gauge?
I was thinkin of using an oil filter sandwich plate, but they look to bling to be any decent quality/good.
Any ideas of where to install the sensor?
Cheers
Ryan
https://www.sau.com.au/forums/topic/124024-install-oil-temp-gauge/
An easier way to measure it is via a oil filter sandwich adaptor, much like this one.
Agreed its the oil before it goes into the motor but unlike a radiator, oil doesn't cool much in the sump before it goes back into the motor.
Yeh that wat i was talkin about that sandwich plate. I dunno about it, looks like it wont give a proper seal and might not last.
Oil cooler is a bit of an extreme as i dont thrash it much :happy:
The other option i was thinkin is makin a T-peice where the sump plug goes and screw it in there. The only thing is swirling of the oil might miss the sensor.
Is there any where in the engine block i can put the sensor (ie unused bolt screwd in the engine)
most oil temp sensors have a large probe.
Greddy make a sump plug replacement that you can screw your sensor into..
if the swirling of the oil misses a sensor there, then your oil pickup wont be getting oil either ..
Good point Craved i wasnt thinkin
Did u have a link or somethin for the greddy plug?
    • All of those are near new/brand new/done under 10,000km! This means something! It also doesn't necessarily mean anything.... The idea is of course to fit wider tyres and rims, and to go with engine head updates, I'm sure it will be faster the subsequent time out. But TBH the difference will largely be in driver mod between one day and the next I'm sure. To say I am unseasoned after many years away from even driving remotely fast is an understatement. Giving it half throttle and "Whoa, that's a bit excessive.." and realizing I'm doing 80kmh in a 100 zone is evidence enough lol. I have noticed that there is heat haze/steam/air/something absolutely steaming out of the car after parking it. I didn't drive it in the 40C day for testing yesterday, but on Christmas day it was ~32 and you could literally see the air coming out from the bay after parking the car. Whether that's enough though..
    • I'll take clutch for 50 Eddie.
    • Standard GTRs are boring and there plenty of them, do what ever you want to it and just remember nothing about them is cheap anymore and if you’re picky about how you want things done it gets even worse.    if it’s an n1 or something very limited then maybe care more about it’s heritage
    • Alright guys, I've got good odds the motor survives due to a majority of spare parts. Who's taking bets on clutch, who's on transmission, and who's go diff? Happy to also take bets on if it still overheats in traffic or not 😛     Car looks amazing by the way. I've never been a fan of R34 rears, so really, I don't think any body kit etc solves that for myself, but the front end looks amazing!
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
